engine stuttering
engine stuttering
ok this weekend i was up in the pocono mountians in pa and everyonce in awhile the engine would stutter like it wanted to stall for no reason. At first i thought it might have been the gas i bought so i got a stp octane booster and stp engine cleaner. which seemed to help a little but still had the problem. i got back home yesterday and now no problem what so ever so now i am thinking might have been something else what do u guys think?
o yea btw i did just finish my exhaust which is .5" larger then stock all the way threw so not sure if that might have some bareing on this.
I think a better description of the stutter; like the condition.. were your idling.. traveling at a constent speed.. Describe what you felt.. what was the rpm gauge doing.. if you gave it some gas (reved the motor) did it stutter while it climbed RPM or did it clear up and reve correctly?>
well it would only happen sometimes when i got to a stop and the idle would drop below 500 rpms. but when i dropped it to nuetral and reved the engine it would be fine. would happen like 2 stops in a row then stop happening. some times while accelerating off the stop that it almost stalled it would feel like it had no power then go back to normal.
A good cleaning of the plunger and the hole it's in solved it for a little while.. Sometimes it would idle down below 500 and die for no reason.. give it gas and it runs fine..
I'm actually replacing mine currently because it started acting up again.. not wanting to maintain idle or idle too high.. the thing was clicking and sticking. So I'm replacing mine.
Trending Topics
btw i just got a code today for both my upstream o2 sensors getting a high voltage reading which i guess could cause some problems. i was wondering what is the standard brand of o2 sensors for the dakota so i can check the ones on the truck to make sure that the muffler shop didnt put in some stupid cheap ****.
