2000 dakota won't shift out of 4WD
Old Jan 29, 2015 | 01:43 PM
  #21
Shufly2's Avatar
Shufly2
Default O boy, 4x4 without 4wd indicator light
Originally Posted by 00DakDan
Yeah the bushings wear out after a while. Glad you have the 4wd working.
Nothing to rewind. Your clockspring is destroyed, guaranteed. It happened when the steering wheel spun. Need a new one.
It connects the buttons for cruise, the drivers airbag, and the horn.
Yes, your horn is dead too.
Disconnect the battery for at least 2 minutes before you pull the airbag. It's not a difficult job once you pull the wheel.
My 4x4 works now, I noticed no 4wd indicator light on dashboard. With no cruise control n the airbag light on? But I've got horn. Gonna pull airbag n see if salvageable clock steering wheel spring. Still do I need to pull steering wheel to check or reconnect 525-103?
Old Jan 29, 2015 | 01:50 PM
  #22
00DakDan's Avatar
00DakDan
Section Moderator
What's 525-103?
Nobody say 422!
Old Jan 29, 2015 | 04:38 PM
  #23
shufly's Avatar
shufly
Default 525-103 clockspring
my p/n for my clockspring
that I hope to get to soon.
but first gotta check oil atf4 in tranny n transfer case.
thanks again.
