Fuel filter
Old Dec 5, 2012 | 10:39 AM
MT1020's Avatar
MT1020
Default Fuel filter
I was wondering where the fuel filter is on my 02 3.9 extended cab and what do I need to replace it? Thanks
Posted from Dodgeforum.com App for Android
Old Dec 5, 2012 | 10:55 AM
00DakDan's Avatar
00DakDan
Section Moderator
It's in the fuel tank. It's part of the fuel pump assembly.
There is no change interval on the filter.
Old Dec 5, 2012 | 11:05 AM
mmguy18's Avatar
mmguy18
That's my understanding fuel filter, pump & regulator are 1 unit.
Old Dec 5, 2012 | 12:39 PM
MT1020's Avatar
MT1020
My V6 is drinking gas. I figures it was the filter causing it..any suggestions?
Old Dec 5, 2012 | 01:08 PM
dodgeramguy85's Avatar
dodgeramguy85
Bad fuel filter will cause poor performance,will stumble at high rpms,randomly shut off and hard starts.
Whats the specs on your truck. If its anything above 13mpg you are about normal. Tune up(plugs,wires,cap and rotor) When was the last time it was done?. Is your throttle body dirty at all? Plentum gasket good? No check engine light?
Old Dec 5, 2012 | 01:44 PM
00DakDan's Avatar
00DakDan
Section Moderator
How many miles are on your truck?
Bad O2's? They do get slow after a while.
Old Dec 5, 2012 | 01:51 PM
MT1020's Avatar
MT1020
I don't know the exact MPG. Didn't do the math yet but I deliver pizzas and normally don't go through a full tank in 2 days. Didn't deliver that much either. The spark plugs and wires were changed about 3-4 months ago not the cap and I clean the throttle body once a month as it gets dirty fast. I dont know what a plentum gasket is. air bag is the only light thats on
Old Dec 5, 2012 | 02:04 PM
MT1020's Avatar
MT1020
Right at 78k. How will I know if its a bad O2
Old Dec 5, 2012 | 02:17 PM
00DakDan's Avatar
00DakDan
Section Moderator
Usually you'll have a CEL.
A good scan tool can do it under "live" data. You can pull the wires and measure the output. It needs to be hot though.
Short trips, lots of idling, will kill your mileage. Track it for a bit and see what you get.
Old Dec 5, 2012 | 10:26 PM
Robbadodge's Avatar
Robbadodge
I assume pizza delivery is not a new job, so it's easy for you to know.
Many auto parts stores will assist with codes. Obviously, air bag alarms won't kill mileage, so looking at O2 codes are a quick find. Mine have never triggered the CEL, and always have an error. There may actually be something wrong with the air mixture too. No codes and changing your sensors will not cure that.... just force you to look while still having the same errors.
What is it, the IAC or something.
My $.02
Good luck!
