No Bus issue
No Bus issue
2004 quad 4x4 4.7
Had the no bus issue. replaced pcm, truck started fine. Alternator seemed to be laboring, checked voltage 17.5, then down to 15 then back up to 17.5 again. Shut truck off, now have the no bus issue again. Truck will not turn over.Tried resetting the pcm, no change. Did I fry the pcm with an alternator that's putting out too much voltage.
Even with a dead PCM it should crank - unless Dodge did something really weird with the wiring in '04.
Unfortunately, I don't have a wiring diagram for '04.
Check for power at the starter. Have someone work the ignition switch so you can see if the solenoid is getting power when in "start."
Trending Topics
What does have power? What happens now when you turn the key? Do you hear a relay click in the PDC? I'm going off of a 2001 diagram so bear with me here. Is there a relay or a fusible link for the starter in the PDC?
Check pin #16, it may be a pink wire, for power at the data link connector.
When I turn the key all the dash lights come to life, the voltage gauge does not move at all, oil pressure moves to the 0 position, THere is a relay for the PDC, have already change it, don't hear any click in the relay in the PDC. I think there is power on the data link as the OBD comes to life when I plug it in, but it cannot connect. Have another PCM to try, its not flashed, Just seeing if I can get it to crank.
