Bad Wheel Hub... Again?
Old Mar 9, 2013 | 01:59 AM
magnethead's Avatar
magnethead
so are our trucks uni-hubs like the rams, old school separate pieces, or what?
Old Mar 9, 2013 | 09:56 AM
01SilverCC's Avatar
01SilverCC
Mine is just a 2 wheel drive truck so it has the one-piece hub/bearing assembly. I also do not have front wheel ABS so there is no electrical connector or tone rings or any of that stuff on the hubs either. I looked at the hub assembly for a 2001 Ram on the Carquest web site, it looks exactly like my hub except that the Ram has 5 lugs and mine has 6.
Jimmy
Old Mar 9, 2013 | 10:10 AM
98DAKAZ's Avatar
98DAKAZ
2 WD http://www.rockauto.com/catalog/more...206&cc=1371877
4X4 http://www.rockauto.com/catalog/more...982&cc=1371877
It depends on your ABS package
Old Mar 9, 2013 | 10:35 AM
00DakDan's Avatar
00DakDan
Section Moderator
One piece, 2 or 4wd.
Old Mar 9, 2013 | 11:32 AM
sxrsil3nt's Avatar
sxrsil3nt
When I installed the new one I didn't torque it. Just got it tight with a breaker car so maybe its my fault. I wouldn't have guessed that though.
I'll work on it tomo and see If I can find anything.
Thanks again
Old Mar 9, 2013 | 12:28 PM
magnethead's Avatar
magnethead
well, I guess so-long-gone are the days of packing bearings...although I prefer the 4x4 style uni-hub like the rams have, vs just the mounting flange that goes on a spindle.
Old Mar 9, 2013 | 03:07 PM
00DakDan's Avatar
00DakDan
Section Moderator
Bearings are one of those things you have to torque correctly. It helps hold the assembly together.
173 foot pounds is the torque. You pretty much have to stand on a short breaker bar to torque it.
Old Mar 9, 2013 | 04:28 PM
98DAKAZ's Avatar
98DAKAZ
From SKF
One of the most common mistakes during installation of a new hub is improper torque of the Axle nut.
To guarantee the (Bearing, Spindle or Hub) is torqued correctly, follow the manufacture’s installation procedure. Ignoring these important details will reduce the life of your (Bearing, Spindle or Hub).
Use a qualified, calibrated torque wrench. Do not use an impact gun to install the axle nut. The impact gun will damage the axle nut. It will also leave your spindle nut under or over torque resulting in hub assembly failure.
Ensure that you have the correct torque for the application by referring to SKF 457377 torque specification guide or contact the vehicle manufactures dealer. It is important that you properly torque the spindle nut to ensure optimum bearing life. Under torque of an axle nut will allow excessive movement causing uneven loading and excessive wear.
Over torque of the axle nut will cause excessive load and cause the bearing to overheat, this is one of the most common causes for failures.
http://www.nordiques.com/pieces/imag...torquesskf.pdf
Old Mar 9, 2013 | 04:29 PM
magnethead's Avatar
magnethead
O.O
BBC Main caps are 110 ft lb and it takes 3 people to do that, we struggle to do it with 2!
Old Mar 9, 2013 | 04:46 PM
98DAKAZ's Avatar
98DAKAZ
A breaker bar or extension can and will give your tourque wrench off readings
a must read
http://www.specialpatrolgroup.co.uk/...ue/torque.html
