check engine light / stall
Old Mar 13, 2013 | 05:55 PM
Dakotaquad's Avatar
Dakotaquad
Default check engine light / stall
ok i went to turn on my truck before and i got a check engine code and the truck just stalled it self. the code i was p0320 what the heck would cause this?? ? code says its a ignition sensor where would i start to look?
Old Mar 13, 2013 | 06:03 PM
00DakDan's Avatar
00DakDan
Section Moderator
The '01 FSM lists it twice. Both point to a bad crankshaft position sensor. What engine do you have?
P0320 - No crank reference signal at PCM.
No reference signal (crankshaft position sensor) detected
during engine cranking.
OR
P0320 No RPM Signal to PCM (Crankshaft Position Sensor Signal to JTEC)
A CKP signal has not been detected at the PCM.
Old Mar 13, 2013 | 07:38 PM
Dakotaquad's Avatar
Dakotaquad
i have the 4.7L
so pretty much i need to check the sensors to the crankshaft ? ?
Old Mar 13, 2013 | 08:39 PM
00DakDan's Avatar
00DakDan
Section Moderator
It's located on the RH rear side of the engine block, just under one of the freeze plugs.
There isn't much to check. Make sure the connector is clean.
$20-30 or so at Rockauto.
Old Mar 13, 2013 | 08:49 PM
magnethead's Avatar
magnethead
and don't break it off!
Old Mar 13, 2013 | 08:59 PM
Dakotaquad's Avatar
Dakotaquad
thx for the info
00Dakdan RH = right head correct so i look in the right place?
Old Mar 15, 2013 | 05:26 PM
Dakotaquad's Avatar
Dakotaquad
btw what would be a good cleaner to use on the connector if it is dirty?
Old Mar 15, 2013 | 07:33 PM
00DakDan's Avatar
00DakDan
Section Moderator
Right hand - on the block, not the head. Just below the freeze plug.
I'd use electrical contact cleaner from the auto parts store.
Old Mar 15, 2013 | 08:17 PM
Dakotaquad's Avatar
Dakotaquad
ok thx
Old Mar 15, 2013 | 09:04 PM
TheePlaymaker's Avatar
TheePlaymaker
I'd replace it, fairly cheap and easy if I remember right. Mine did this twice both times after I went through the car wash. It would start but I had to feather the gas to start it like it was an old carbed motor. I replaced the cam and crankshaft position sensors and it hasn't happened since, I think I was pulling 2 codes, that one sounds familiar though.
