Dakota brakes suck!
Old Apr 14, 2013 | 09:42 PM
milo09's Avatar
milo09
Yep I'm guessing booster too .....my brake pedal stays firm though when the engine is running and I unplug booster
Old Apr 14, 2013 | 09:44 PM
magnethead's Avatar
magnethead
are you saying it's hard with engine off and goes to the floor with it running (which is what mine does)? Or is it hard and goes to the floor if you stand on it (engine on/off?)
Old Apr 15, 2013 | 10:01 AM
milo09's Avatar
milo09
Yes, lose pedal to floor when started up. Headed out to tinker......going to looks at each brake
Old Apr 15, 2013 | 10:48 AM
00DakDan's Avatar
00DakDan
Section Moderator
Engine off, or vacuum line disconnected, a hard pedal is normal. You won't have the vacuum to assist.
If the pedal goes to the floor it's a base brake system problem, like air in the lines, brakes out of adjustment, leaking wheel cylinder or caliper, or a bad master cylinder leaking internally. If you installed the master cylinder without fully bleeding it the first time you have a lot of air in the lines.
Drum brakes, not adjusted properly, will give you a low pedal.
I don't believe you have ANY problem with your power booster.
Old Apr 15, 2013 | 12:36 PM
magnethead's Avatar
magnethead
as I said before, my pedal goes to the floor and the truck will stop on a dime. I've just gone ahead and called it normal.
Old Apr 15, 2013 | 01:10 PM
milo09's Avatar
milo09
Well.........took off LF caliper all cheeks good. Took off RH caliper and found inner pad broke loose and very thin. Looks like I found my problem....now if I could only remember which caliper I replaced last year?
Old Apr 16, 2013 | 10:09 AM
milo09's Avatar
milo09
Ok......replaced bad caliper and installed new pads....re-bled system back to front. Still pedal goes to floor? I'm guessing booster now? At $100 for new I'm off to junk yard tomorrow as they are only $20
Old Apr 16, 2013 | 11:01 AM
00DakDan's Avatar
00DakDan
Section Moderator
No offense, but you ARE guessing.
Think about how the system works. The booster has no connection to the hydraulics, it just helps you push the pedal down.
You can not compress a liquid, no matter how hard you press. If it goes to the floor slowly, it's a leak, internal or external. If it's just low the drum brakes are not adjusted properly.
Good luck.
Old Apr 16, 2013 | 11:08 AM
milo09's Avatar
milo09
At this point ....i am guess!! But now that I think about it...I'm going to look into the
RWAL
Old Apr 16, 2013 | 11:25 AM
sl2racer's Avatar
sl2racer
i have to agree. it sounds like you still have air in the line. i don't think it is a booster problem either.
