Dakota brakes suck!
Old Apr 13, 2013 | 09:48 PM
milo09's Avatar
milo09
Angry Dakota brakes suck!
1999 3.9 2WD
Brake pedal goes to floor...........
Replaced: master cylinder and booster check valve
I have bled master and front brakes....still pedal goes to floor but does stop wheels.
Help....been without my truck for a week now.
Old Apr 13, 2013 | 11:50 PM
sl2racer's Avatar
sl2racer
u generally bleed front and backs. specially when you replace a master cylinder.
Old Apr 13, 2013 | 11:54 PM
magnethead's Avatar
magnethead
bleed the master on the bench, then backs, then fronts. My pedal stops about the thickness of my left foot from the floor (IE, I can stomp my left toes by pushing the pedal with my right foot) and my truck stops on a dime, literally.
Old Apr 14, 2013 | 06:41 PM
milo09's Avatar
milo09
Busy day.......bled master cylinder on bench, bled backs to fronts....still no brakes!
Checked brake booster per dodge vacuum test....passed.
What in the world am I missing?
Old Apr 14, 2013 | 06:50 PM
Tom A's Avatar
Tom A
Section Moderator
Have you pulled the drums off the rear to be sure the brakes are working as they should? I've seen stuff like wheel cylinder pushrods that weren't seated in the shoes.
No matter how well the hydraulic part of your brakes work, they won't do much if the mechanical parts aren't right.
Old Apr 14, 2013 | 07:55 PM
98DAKAZ's Avatar
98DAKAZ
You Shure you have the correct master there are 4 or 5 for the second gen depending on 4W or 2W ABS and each engine size according to different brake sizes also.
But I think you have something other going on
Did you get fluid out of the back brakes when bleed?
Old Apr 14, 2013 | 08:01 PM
milo09's Avatar
milo09
I adjusted the back brakes...they were loose. Spun rear wheel after it brakes stopped rear wheels. The master cylinder is correct - they gave me the incorrect one the first time!
I did get fluid out of the back breaks when bled also.
Old Apr 14, 2013 | 08:03 PM
98DAKAZ's Avatar
98DAKAZ
Can you provide more detail on the problem?
You may need to flush out all the old DOT 3 air may be in the ABS crap
Old Apr 14, 2013 | 09:02 PM
milo09's Avatar
milo09
My brake pedal goes to the floor.....the pedal is hard till I start the engine.
Old Apr 14, 2013 | 09:07 PM
98DAKAZ's Avatar
98DAKAZ
Did you forget to connect the power boost vacuum line
Other than that I think something was installed wrong
It does sound like the power booster
