Verify power at the power outlet, not by plugging something in, but by testing the connections to the outlet.
I couldn't find any letter markings for the fuse. On the inside door of the cab fuse box, there is a cig ltr on #17. It was blown to I checked it with the volt meter. Yup, 30. It's supposed to have a 15 in it.
There is a wire hanging in the back of the bed that looks like it might have been lighting for a topper. So I plan to trace it back. I'm hoping it's almost on the same circuit.
just a thought that i would like to share with my experiances. When i first purchased my truck not of the power outlets or the cig lighter worked. replaced both fuses and no change. Turns out the the outlet itself went bad. I picked a few up at the junkyard and they have worked ever since. Might be worth your while to pull a few things apart and check it at the wires with a volt meter.
Under the hood, in the Power Distribution Center (PDC) fuse D, 20 amp.
I have a 2000 Dodge Dakota Sport power outlet fuse is blown and I don't know how to change it, I don't know where the fuse boxes located for the auxiliary outlet
what does the fuse look like the is a 50 amp fuse is that it
