A/C leak
Old Jul 28, 2013 | 04:46 PM
53fireman's Avatar
53fireman
Default A/C leak
2001 Dakota regular cab with the 3.9 engine...
A/C used to work great, then one day after sitting for a few days, it stopped blowing cold. Refilled the freon and it blew cold for 2 days, then stopped again. We replaced the low side schraeder valve because it was bubbling very slowly out of there and refilled again. With the AC on max, about 75 degrees outside, the low side pressure was 35, and the high was only at 170. Still only works for 2 days then stops.
Any ideas before I have to either take it somewhere or start replacing parts piece by piece?
Thanks
Old Jul 29, 2013 | 06:02 PM
gnelson49's Avatar
gnelson49
For starters, what are you using to measure pressures? A good gauge set or the cheapy gauge that comes on the refill kits? A leak is usually indicative of other issues.
Questions to answer:
1. Have you ran UV dye through the system to check for other leaks?
2. How much freon are you adding to the system when you refill?
3. Have you opened the system up to outside air? (This would require having the system evacuated of moisture prior to recharge)
4. Is the compressor running still when it is no longer blowing the cold air?
From the sounds of it you could have a clogged orifice tube, more leaks, and possibly a failed or failing component plugging up the system.
Old Jul 29, 2013 | 06:53 PM
00DakDan's Avatar
00DakDan
Section Moderator
Time to check for leaks. Put in some dye and get out the UV light.
They could be anywhere. Check the condenser, maybe you picked up a rock. Then check all the lines. You can also have a leak in the evaporator, or at the compressor.
Old Jul 30, 2013 | 02:04 PM
53fireman's Avatar
53fireman
Using legit gauges, but don't have a scale, so not 100% sure how much we added. Just put in enough to bring the pressure up to make sure the compressor kicked on. Going to look at getting a dye kit.
Old Jul 30, 2013 | 05:25 PM
00DakDan's Avatar
00DakDan
Section Moderator
Whatever you do, do NOT put in any stop leak. No shop will touch your truck if you do.
Old Jul 30, 2013 | 08:18 PM
53fireman's Avatar
53fireman
Thanks, while looking for the dye kits, there were a lot of the stop leak kits coming up too. Some had good reviews, but I guess that's not the best route to go.
Old Jul 31, 2013 | 12:14 PM
98DAKAZ's Avatar
98DAKAZ
Use Nylog (Blue) Gasket Thread Sealant for HFC Systems on all your O-rings and connections to guarantee no leaks.
Great stuff
https://www.ackits.com/pc/RT201B/Nyl...or+HFC+Systems
Old Jul 31, 2013 | 12:16 PM
98DAKAZ's Avatar
98DAKAZ
DO NOT USE ANY stop leak
Very bad crap
