My First Engine Swap
Old Sep 10, 2013 | 08:03 PM
  #41
sxrsil3nt's Avatar
sxrsil3nt
So I pulled the cover off today, everything looked good except this one spot:
Is this any major cause for concern? I've come to know that shiny spots are not good. The actual teeth of the chain seem fine, it just looks like something scraped this part here... very few metal shavings but I thought I'd check just to make sure:
Thanks
Old Sep 12, 2013 | 08:56 PM
  #42
AndrewRobertson's Avatar
AndrewRobertson
nice thread. going to watch tthis.
Old Sep 13, 2013 | 11:51 AM
  #43
Brian in Tucson's Avatar
Brian in Tucson
Thanks
Hard to see any unusual shiny spot. I do see clean metal under flaking off sludge deposits, tho. I don't think I'd worry about it. (and I'm a habitual worrier!)
Old Sep 13, 2013 | 12:43 PM
  #44
sxrsil3nt's Avatar
sxrsil3nt
Yeah I've decided its fine. I also noticed there are tiny hairline cracks inside the cover but I found thats normal for aluminum.
The plan is to get the cover and water pump on tonight so the engine can go in tomorrow.
That is unless I run into more problems lol
Old Sep 13, 2013 | 01:20 PM
  #45
magnethead's Avatar
magnethead
So did you just tear down your blown motor, or get the newer one machined?
Old Sep 13, 2013 | 02:48 PM
  #46
sxrsil3nt's Avatar
sxrsil3nt
Neither. I was adding my old water pump to the used engine I picked up but I also wanted to see the condition of the chain so I pulled the timing cover too.
Old Sep 14, 2013 | 05:26 PM
  #47
sxrsil3nt's Avatar
sxrsil3nt
Timing cover, waterpump, harmonic balancer, and a POR15'd oil pan is done.
Engine is going in tomorrow. I'll post some pics then.
Old Sep 15, 2013 | 05:30 PM
  #48
Brian in Tucson
POR15 in the oil pan? Why?
Hope the install is going okay, btw. Getting everything lined up ain't as easy as it looks on TV, is it? Guide pins (long bolts with the heads cut off) can be your friend.
Old Sep 15, 2013 | 05:41 PM
  #49
magnethead's Avatar
magnethead
I thought you bent the rods in your old motor when you hydrolocked it? So you just changed water pumps and that's it?
Old Sep 15, 2013 | 05:53 PM
  #50
Brian in Tucson
He was given a replacement motor, but it ended up having rust seized pistons, so then he bought a junkyard motor with a 6 month guarantee or some such thing. He transferred his almost new water pump to the junkyard lump.
