Lost 4x4 after muddin 2001 DAKOTA SPORT
Old Sep 18, 2013 | 09:37 AM
mchll18's Avatar
mchll18
Default Lost 4x4 after muddin 2001 DAKOTA SPORT
After comin out of the mud I was hearing a grinding sound. Turned off the 4 wheel drive and it went away. Now I I have no 4 wheel drive and the light on the switch went out. If u turn the **** nothing happens. What do u think it is? Oh and I had someone hook a computer to it and was able to turn on the 4x4 also with the grinding sound. Plz help!!! Need to get it fixed before winter.
Old Sep 18, 2013 | 09:56 AM
sxrsil3nt's Avatar
sxrsil3nt
Check your tcase and dif fluids.
Could be a wiring issue with the switch too. Have you checked fuses?
Old Sep 18, 2013 | 10:00 AM
mchll18's Avatar
mchll18
Yea the fluids are good. And the switch is good except for the light not being on I was told.
Old Sep 18, 2013 | 10:15 AM
sl2racer's Avatar
sl2racer
maybe the actuator got mud in it and isn't fully in-gauging the 4wd which gives your light on the 4wd switch no idea if it is in 2wd or 4wdhigh or 4wdlow.
Old Sep 18, 2013 | 10:22 AM
mchll18's Avatar
mchll18
Someone asked me about the actuator once but I have no idea was that is. So maybe I need a new one?
Old Sep 18, 2013 | 11:23 AM
mchll18's Avatar
mchll18
Does anyone else think it's my actuator?
Old Sep 18, 2013 | 12:08 PM
00DakDan's Avatar
00DakDan
Section Moderator
Not to sound negative but I think you need to do more diagnosis.
Could it be the actuator, yes. Could it be something else, yes. You may have internal damage to the transfer case, maybe a shift fork.
Just throwing parts at it could get expensive.
Old Sep 18, 2013 | 12:48 PM
mchll18's Avatar
mchll18
So how do I find out for sure?
Old Sep 18, 2013 | 01:41 PM
magnethead's Avatar
magnethead
I'm with Dan. Either the actuator got mud packed, or the shift fork for bent in the casing.
Who's bright idea was electronic shift transfercase, anyways?
Old Sep 18, 2013 | 09:56 PM
sl2racer's Avatar
sl2racer
i wasn't saying throw parts at it. i was suggesting where to look.
