Are 00 and 02 Dakota engine interchangeable
Welcome to the forum Gerald.
Which engine?
If it's the 4.7 then you need to be careful of the tone rings. They should both use the JTEC (3 connector) PCM but there is a chance that the '02 is using the NGK (4 connector) PCM. If so, they are not compatible without changing tone rings.
As long as you verify you have a 3 prong PCM in the '02 you are good to go. Use the sensors from the '02.
Which engine?
Which engine?
Which engine?
Even if I swap over the sensors and stuff?
Trending Topics
YES!
Inside the engine and on the camshaft are "tone rings." They control fuel sync and ignition timing. Your '02 should have a 3 prong PCM, most did, but there are a few that did not. If it has 4 connectors you would have to OPEN the '00 engine and replace the tone rings.
If your '02 has 3 connectors, the tone rings are correct. Only a 3 connector PCM was available in '00.
The sensors have nothing to do with the tone rings.
Which is what I'd do. Give you a chance to check out the engine a bit and replace some seals.
