2.5l Question
I am wondering if I could convert a 2.5l to carb by just plugging the injector bosses and bolting a carb on? Could I keep the original distributor too? Also will the NV3500 work without a computer?
Also, yes. The 2.5 is also a jeep motor, I bet you can find a carburetor intake fairly easy, unlike the 3.9. Heck, even the 4.0 jeep carb manifold will bolt up to the 2.5 i bet.
And I would sure certainly hope that a manual transmission would work without a computer.
I have read in a couple of places that the Dodge and Jeep 2.5 were different but I don't know. In case anyone is wondering I am thinking about building a small 4x4 buggy for mudding. I have a choice between the 2.5 and 3.9 I my local junk yard. So will the NV3500 work without the computer or would I have to find a different trans?
Earlier years used to have a speedometer pinion in the tailshaft. The newer NV3500's don't.
Actually, for a 2.5 the NV1500 is fine, or even the AX15.
What do you want to use for the ignition? That will influence your decision on the distributor. Some electronic versions are programmable.
