Lift
Old Dec 10, 2013 | 12:48 PM
  #31
TheNewbie's Avatar
TheNewbie
Originally Posted by Babyzila1
If I got a suspension lift and body lift would i still need the diff bracket
If you just do a body lift then no, it won't make any difference. With a body lift your suspension geometry isn't changing at all so the ride will stay the same as it was before, the towing capacity etc will also stay the same.
If you start changing the suspension itself that's when things can start to get interesting. You will never NEED the diff bracket you're talking about, but it will help with premature wear. I did about a 1.5"-2" torsion crank and I have replaced my passenger side CV axel twice in the last year and a half as well as new inner tie rods and tie rod ends. My upper ball joints are also in need of replacement. Some of that was already close to needing replacement just because it had 150,000 miles on it, but the fact is that cranking the torsion bars changes the angles and puts more stress on the front end components. you don't get this with the body lift.
If I were you I might look into 33's over 35's. Decide if you want to do a suspension lift or a body lift and go from there.
A 2 or 3" body lift would clear 33's without touching the suspension. Or you could do like I did and put 1.5" lift blocks in the rear and do a torsion crank up front. At the end of the day it's your truck and your choice, but I'd say that if you are dead set on running 35's you need to do A LOT more research first. There are a lot of factors to consider and I'd hate to see you stuff a pretty brand new 35 into the sheet metal and do hundreds of dollars worth of body damage. Without the right amount of lift and the right backspacing on your rims that is almost a guarantee.
Old Dec 10, 2013 | 12:55 PM
  #32
TheNewbie's Avatar
TheNewbie
If you go with a suspension lift something like this wold work:
http://www.ebay.com/itm/Dodge-Dakota-4-7-V8-2-LIFT-BLOCK-KIT-4x4-/221291696276?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ADakota&hash=item3386035094&vxp=mtr
Keep in mind that the front of your truck probably sits lower than the rear as it is now. that's why I only did a 1.5" lift int eh rear and cranked the front closer to 2". You could go with anything from a 1.5" to a 2" in my opinion. You just need a kit with the blocks and longer u bolts. Don't worry about a kit with the front indexing keys. All you do to lift the front is turn one bolt on each side until it's at the right height. Then you'll have to get an alignment after that so factor that into your costs. Figure around $60-100 for the lift plus probably $50-80 depending where you go.
A body lift will probably put you in the $225-400 range depending on which kit you buy but you won't need an alignment afterwards.
Old Dec 13, 2013 | 05:16 PM
  #33
Babyzila1's Avatar
Babyzila1
What are good tires and wheels that will fit 33s on 3 inch suspension lift
Old Dec 13, 2013 | 06:57 PM
  #34
Babyzila1's Avatar
Babyzila1
http://www.4wheelparts.com/Wheels/Se..._pn=PCW51-5865
Wud these work with a 33
Old Dec 13, 2013 | 08:33 PM
  #35
Tom A's Avatar
Tom A
Section Moderator
They'll work fine with 33s, but they're the wrong bolt pattern for your truck.
These should work.
Old Dec 13, 2013 | 08:50 PM
  #36
Babyzila1's Avatar
Babyzila1
What is a good wheel and tire to put on it
Old Dec 13, 2013 | 08:54 PM
  #37
Tom A's Avatar
Tom A
Section Moderator
Wheels are really a personal preference thing. For tires, it depends what you plan to do with it and how much you want to spend.
Old Dec 13, 2013 | 08:56 PM
  #38
Babyzila1's Avatar
Babyzila1
What about size like to fit 33 what would the size of the whheel need to be
Old Dec 13, 2013 | 09:02 PM
  #39
Tom A's Avatar
Tom A
Section Moderator
A 33x12.50R15 tire will fit nicely on either a 15x8 or 15x10 rim. Some would say it looks a little better on the 10-inch rim, but it's also more likely to rub your fenders, less protected from rim damage in rocks, and will be a little harder on wheel bearings. Personally, I would (and did) go with the 8-inch wide rims.
I used to have a 5.5" Tuff Country lift on my truck with 33s and 1" wheel spacers/adapters and the tires still used to rub the fenders once in a while when the suspension was compressed while the wheels were turned. Keep that in mind if you plan to use the truck off-road.
Old Dec 13, 2013 | 09:07 PM
  #40
Babyzila1's Avatar
Babyzila1
So I have a 3 inch so I can run 33 no problem off road
