trans slipping
trans slipping
I have a 98 5.2l dakota(219,000 miles and i think stock trans) and was wondering if something could be causing it to slip or the fact that its just old. I've only noticed it when cruising and like when it is overdrive. It was happening when i was cruising at 30 today(first time for that usually its around 60) but its just the rpms jump a little(about 500 max) and the it catches and you can feel it jump when it catches. Sometimes it will throw you back in your seat and sometimes you can barley feel it.
It does leak(i think at the main seal) but it always starts to slip and act funny when i actually check the fluid and put some in it. If i just leave it and drive it, it doesn't happen as much.
Last thing is i have a wire at the bottom of the trans(not sure which side) but i know the wires are showing and didn't know if that could have anything to do with it
Well I never had that problem that but I pulled my auto out and putting in a manual.... But I still have the auto out of my truck it's a 97 it'll bolt up and work but the trans is going to need the transfer case because I needed it for my manual because that transfer case was busted.... A 231d transfer case will bolt up to it because that's the one I took off of it, but I would try and tape the wires up so there not shorting or grounding out, do you have any codes?
No codes and i figure it needs a rebuild and want to its just being in high school still don't really have the money to do it.
i thought it may have something to do with my overdrive but this was the anwser i was looking for, thanks
if this is happening at mostly cruising speed,then it sounds like your lockup is going out in the torque converter
This thread might be helpful: https://dodgeforum.com/forum/2nd-gen...ml#post3052076
Do you have auto shop class at your h/s? Or in your school district? Use to be, when I was a kid, the teachers for those classes were pretty good mechanics as well.
Do you have an after school job--have you thought of looking for a job as a helper at a local transmission shop? I did that for a Ford dealership for a while in college. Didn't pay much, but I had the run of the shop on Saturday afternoons when they were closed.
