What calipers do you recommend?
Old Jul 17, 2014 | 12:14 PM
stefanwlsn's Avatar
stefanwlsn
Default What calipers do you recommend?
Time to replace my stock calipers. Which ones do you all recommend?
Old Jul 17, 2014 | 12:51 PM
magnethead's Avatar
magnethead
do you mean pads?
Old Jul 17, 2014 | 01:14 PM
00DakDan's Avatar
00DakDan
Section Moderator
What vehicle? Is this for your Ram?
Old Jul 17, 2014 | 01:42 PM
sxrsil3nt's Avatar
sxrsil3nt
Funny this is posted today.
I just got a set of AC Delco's today st lunch for my truck. I've got one that's sticking quite bad.
Hopefully they will treat me nice!
Old Jul 17, 2014 | 03:16 PM
stefanwlsn's Avatar
stefanwlsn
not pads... I meant calipers. My piston is cracked and I need to replace on so I will just replace the set. All I can find are Cardone and Centric and I have zero experience with either.
Old Jul 17, 2014 | 03:49 PM
01SilverCC's Avatar
01SilverCC
I put Cardones on my truck 3 or 4 years ago, they are still working fine today. I also had a cracked piston in one of my OE calipers. It was my own fault though from being in a hurry and pushing the piston back with Channellocks instead of a C-clamp. You can use an online discount code and get new calipers for a good price at Advance.
Jimmy
Old Jul 18, 2014 | 08:33 AM
Dodgevity's Avatar
Dodgevity
Jimmy, you can use either. Just use one of the old brake pads and place it over the piston before compressing. That also helps to keep it level. If the piston leans, it can damage the seal or introduce air.
I've had my bonehead moments while doing brakes. Like forgetting and pushing the brake pedal with the calipers hanging. You know what that does.
Old Jul 18, 2014 | 10:15 AM
98DAKAZ's Avatar
98DAKAZ
Been their done that pedal to the floor
freaks you out bad
then mad pedal pumping action starts
Old Jul 18, 2014 | 06:38 PM
Tom A's Avatar
Tom A
Section Moderator
I'm not really sure there's one brand of remanufactured calipers that stands out above the rest. My current ones are from Auto Zone (Duralast?), but I've also used Raybestos, AC-Delco, and Bendix calipers with no issues.
Old Jul 18, 2014 | 07:44 PM
00DakDan's Avatar
00DakDan
Section Moderator
Does anybody rebuild their own anymore?
