1997 V6 3.9L low port for AC recharge
Old Jul 28, 2014 | 06:07 PM
jmdomke37's Avatar
jmdomke37
New Member
Default 1997 V6 3.9L low port for AC recharge
Hey everyone, I'm new to this forum and I have searched all over the internet but cannot find a definite answer. I am having trouble determining where the LOW port is for an AC recharge. I see one port on top of the condenser with a large black cap on the side of one of the silver lines (and the AC recharge bottle doesn't fit on it), and another port above the passenger side headlight connected to the radiator with no cap. I'm just afraid I might accidentally connect it to the HIGH port. If anyone could shed some light on this, maybe even with a picture that'd be great!
Old Jul 28, 2014 | 06:18 PM
jmdomke37's Avatar
jmdomke37
New Member
Forgot to mention it's an SLT
Old Jul 28, 2014 | 07:07 PM
00DakDan's Avatar
00DakDan
Section Moderator
The one on the condenser is the high pressure port.
You can also follow the line back from the accumulator to the compressor. That's the low pressure side.
Do find a cap for that high pressure port when you get done. Please use a real gauge set too.
Old Jul 28, 2014 | 07:23 PM
jmdomke37's Avatar
jmdomke37
New Member
Thanks for the reply! I believe I worded this wrong. The port with the black cap that doesn't fit the bottle is on top of the compressor, and the port with no cap is above the radiator.
Old Jul 28, 2014 | 07:51 PM
00DakDan's Avatar
00DakDan
Section Moderator
Follow the lines or post a picture. There are variations depending upon the year and engine.
You really shouldn't be able to make a mistake hooking it up.
Make absolutely sure the can of r134a DOES NOT contain any sealer. If it does and you ever need to take it to a shop for a/c service most won't touch it.
Old Jul 28, 2014 | 10:02 PM
jmdomke37's Avatar
jmdomke37
New Member
I'll see if I can post some pics tomorrow
Old Jul 29, 2014 | 11:59 AM
jmdomke37's Avatar
jmdomke37
New Member
Old Jul 29, 2014 | 12:49 PM
98DAKAZ's Avatar
98DAKAZ
I have seen this before no low side port
Its been monkeyed with someone goofed up you have 2 high side ports and no low side port a very poor fix by someone.
Old Jul 29, 2014 | 01:29 PM
98DAKAZ's Avatar
98DAKAZ
Pic of were it should be a poor Pic but all I could find the low side line is always the larger diameter line going into the compressor
This is what you need as a new replacement part its called a suction & discharge line
http://www.wholesalemopar.com/parts_catalog.html look under HVAC for a 97 Dakota
Old Jul 29, 2014 | 01:37 PM
00DakDan's Avatar
00DakDan
Section Moderator
I agree with '98. From what I can see you don't have a low pressure port.
The port near the condenser is high, the one at the compressor is also high, it should be on the other side.
Pull the air cleaner housing and check the lines.
