That brings up a question. Should I remove paint from areas where there is a seal? For instance, when I install the water pump should I remove the paint around where the seal is?
Not sure on the OHV motors, but there should be a cork gasket. No sealant. criss-cross pattern, usually hand tight (no ratchet, spin the socket on an extension) plus 1/4 turn.
