dakota 2003 probleme
Old Jan 5, 2016 | 08:36 PM
adamo1288's Avatar
adamo1288
Default dakota 2003 probleme
hello there .. i got a dodge dakota 2003 4.7 and today it started making a wierd noise from around the fan clutch and there some metal grind around too ... and the truck stopped while on the drive...restarted it and shutted down after 10 seconde .... any help plz thank you .. and theres a video too u can ear the noise https://www.facebook.com/adam.allard.988
Old Jan 5, 2016 | 08:52 PM
That's a link to your Facebook page....are we supposed to like you first in order to view this video?
Possibly the fan clutch is toast.
Old Jan 5, 2016 | 09:08 PM
adamo1288's Avatar
adamo1288
hmmm i dont know for the facebook page :P i cant link it here dunno y but if u dont mind add me as a friend to see the video and remove me after if u want :P
and if the fan clutch is death i can make my truck to stop running ?
Old Jan 5, 2016 | 10:25 PM
Dodgevity's Avatar
Dodgevity
Luckily, there is another place you can post the video. It's called youtube.com. A seized fan clutch would burn through the drive belt and that would quickly cause a whole host of things to stop working. Things such as the alternator and water pump.
Old Jan 5, 2016 | 10:39 PM
Yeah. Use you tube. I'm not going to go searching through your Facebook for a video. Lol
Old Jan 5, 2016 | 10:49 PM
RalphP's Avatar
RalphP
Umm ... Fan clutch? No. What happens is the fan is run 100% all the time when the fan clutch seizes.
Or the fan blade comes off if it comes apart.
But no, it won't burn through the drive belt.
You're thinking of an idler, tensioner, or some other driven item off the belt (smog pump, power steering pump, whatever.)
RwP
Old Jan 5, 2016 | 10:59 PM
adamo1288's Avatar
adamo1288
ok look at this pics ..theres some metal grind right here where the red circle is
this is the back of the fan clutch and it make some metal grind sound coming right here too so no choice :P
and this is not a picture of my truck its google
Old Jan 5, 2016 | 11:02 PM
That's the water pump. It's probably bad. Take the belt off and see if you have any play in the cooling fan. If it wobbles at all, time for a new water pump.
Old Jan 5, 2016 | 11:05 PM
adamo1288's Avatar
adamo1288
okok and for the metal up the water pump and the noise like metal rubs any idea ?
Old Jan 5, 2016 | 11:07 PM
adamo1288's Avatar
adamo1288
https://www.youtube.com/watch?v=w0u6...ature=youtu.be
that the sound im talking about from my truck and its coming from the fan clutch or the water pump
