04 dakota wont start
Old Oct 29, 2017 | 03:35 PM
Alex Coombs's Avatar
Alex Coombs
Default 04 dakota wont start
I went through some puddles yesterday and it was driving good for while then when i got to the main road i noticed the check engine light and it wouldnt go over 3000 rpm when i floored it. I let it sit for a while later and it started up and stalled twice. Now it turns when i try to start it but doesnt fire up.. got the codes on the dash p0068 and p0513 the first time but now im just getting pDone.. i tried reseting it by dissconecting the battery for a while but it still wont start. Any advice would be appreciated!
Old Oct 29, 2017 | 08:34 PM
Something got wet.... Might be the connections at the PCM, might be the distributor.... (depending on which engine you have.....)
Old Oct 29, 2017 | 10:21 PM
Alex Coombs
I took out and dried all the spark plugs to get it running again but i have to unplug the intake air temperature sensor and floor it to make it start up. Now the rpm is all over the place and i dont think its shifting into gear now. Couldnt go very fast in my area but i was hitting over 3000 rpm only accelerating a little bit..
Old Oct 29, 2017 | 10:22 PM
Alex Coombs
Its got the 4.7 v8 magnum
Old Oct 30, 2017 | 09:32 AM
00DakDan's Avatar
00DakDan
Section Moderator
p0068 is a map sensor/throttle position sensor correlation problem. You may have gotten either one wet. Hopefully it isn't the map sensor or you likely took a big slug of water into the airbox. Replace them.
P0513 is a SKIM key issue. That'll keep you from starting. The SKIM module doesn't recognize the key.
