Transmission Interchange 97 Dak 3.9 engine
#21
You could check TV cable adjustment, and verify it is correct. That's free. I would be tempted to plug a scanner into it, and see what the output speed sensor was telling the pcm before replacing it... if it gives erroneous readings, then yeah, time for a new one. If it reads correct, then you will need to look elsewhere for the problem.
#22
Well in short I am just totally disgusted. I feel like I am on a never ending merry go round. After all I have done I do a little work on my truck like checking the plugs and wires ..it had a miss. Found and fixed that so I took a drive and now it won't go into lock up again. Could I need to replace the outer plug ( 8 Pin ) as well I read somewhere that can cause problems as well...
#24
#25
Well that's odd. If things aren't working right, I would like to think the PCM would notice....... The plug not having the clips anymore *may* be an issue. If it isn't making good contact.... things get weird. But, again, I would like to think the PCM would notice, and complain about it......
#26
Come to think of it I am experiencing some weird stuff else where to so I may start looking for a PCM to see if that is messing me up.. I am going to get My friend that has the Garage to plug it in and see if that shows up then I trust him more.. Oh and the check engine light is on and I fixed all the other stuff and cleared the puter and the light came right back on.. Was just talking to another Trans mechanic and he is saying I may need to switch the Valve body from my old one to get it to shift right and do the lock up over drive..
