Update On New PCM
09-04-2018 | 09:44 PM
So you got voltage. It should also pulse while cranking. (signal wire.)
09-04-2018 | 11:09 PM
There are 3 wires i believe but yes one pulsed during cranking.
09-05-2018 | 09:00 AM
Yeah, 5 volt feed, sensor return, and ground.
So the cam sensor is doing it's job...... Is the PCM getting the clue though.... Can you test for signal AT the PCM?
09-05-2018 | 09:21 AM
Not sure how to properly test the PCM sorry.
Is there a particular wire(s) i can look for?
09-05-2018 | 09:23 AM
Check the sensor return wire for the cam sensor back at the pcm. Have to poke a probe into the wire...... (tape it up later.) Just checking to see if the signal is making it back that far.
09-05-2018 | 09:25 AM
Ok would that be a 5v test as well or 12v?
09-05-2018 | 10:28 AM
5 volts.
Blinks while cranking or running.
09-05-2018 | 10:59 AM
Thanks I'll test it between rain drops lol, been storming here for 5 days
09-05-2018 | 12:16 PM
Ok no blinknig or pulsing during cranking at Cam censor, just solid light. Tested all 3 wires.
09-05-2018 | 04:21 PM
That would explain a lot. Seems like you have a short somewhere in the wiring for the cam sensor then. That should be just a joy to find.......
