99 dak club cab sport 5.2 with a nv3500 swap QUESTIONS
Old Sep 6, 2018 | 06:41 PM
frankensteinbuilds's Avatar
frankensteinbuilds
Was it originally a 4x4, and you changed to a 2wd trans? wonder if the driveshaft is simply too long.
Also, lots of crud around the pinion seal on that rear diff..... or is that just the lighting?
should be a 4x4 trans I ordered it as a 4x4 trans and bought a "manual trans drive shaft aswell " the pinion ya both battery was low and flash wasn't working and I'm sure their is a slow leak its got 280K on it
Old Sep 6, 2018 | 07:08 PM
I'm not seein' the t-case?
Well, not like it doesn't have an excuse then.
Old Sep 6, 2018 | 07:21 PM
frankensteinbuilds
Old Sep 6, 2018 | 08:18 PM
Oh. Yeah. It was too close.....
Is that the correct rear mount there? Almost looks like there is two?
Old Sep 6, 2018 | 10:38 PM
frankensteinbuilds
So in the pic from bottum to top is frame trans cross member mount and trans bottom (the mount is the mount orilys computer said was the right one ) ......also happens to be same as the auto mount.....minus the second mount
