IAC stays extended when cold
Old 10-03-2018, 09:47 AM
willie101474's Avatar
willie101474
willie101474 is offline
Default IAC stays extended when cold
Hello all. I am having trouble with my 97 dodge dakota 3.9L. The plunger on the IAC is all the way extended when the engine is cold causing it to not get air and not stay running unless I keep on the gas. I have replaced it three times so I am sure its not the IAC itself. Any ideas on what would cause this?
Old 10-03-2018, 11:21 AM
hidden1's Avatar
hidden1
hidden1 is offline
Any codes?
Fuel an spark tested?
No air leaks?
Old 10-03-2018, 11:27 AM
willie101474
Originally Posted by hidden1
Any codes?
No air leaks?
No codes. Spark and fuel is fine. It will run if i manually push the piston back on the iac. I don't see any air leaks but I did read that would cause the condition.
Old 10-03-2018, 06:04 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,276 Likes on 3,023 Posts
Verify you are getting 12 volts on the IAC connector on TWO wires.
Old 10-05-2018, 09:38 AM
willie101474
I have 12v on two wires and ground on the other two
Old 10-05-2018, 09:44 AM
HeyYou is offline
That is correct.
Reinstall the IAC. Disconnect the battery for a while, to reset the PCM. Hook it all back up, turn the ignition to 'on', (not start) count to ten. (don't touch anything) THEN start the truck. See if it doesn't straighten up, and fly right.
I put an aftermarket IAC in my 96 Ram, and had intermittent stalling issues. Replaced it with a mopar unit, all problems gone........
Old 10-05-2018, 01:03 PM
hidden1's Avatar
hidden1
hidden1 is offline
I agree some sensors are brand sensitive.
RESET system/ecm.
Be sure its seal / o ring is good too.
Maybe get a mopar one off same truck to see what it does .if problem is still there .after reset.
Old 10-05-2018, 01:50 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
The IAC has an o-ring if not thats your problem or you have an air leak thats the only reason it would be extended like that.
Old 10-05-2018, 02:18 PM
hidden1's Avatar
hidden1
hidden1 is offline
That's what I just said yes..
must be sealed by o ring
Old 10-06-2018, 12:49 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Question
Well excuse me what is this an exclusive thread of yours?
Quick Reply: IAC stays extended when cold
