Blown transfer case??
Old 12-23-2018, 06:27 PM
moparguy44's Avatar
moparguy44
moparguy44 is offline
Default Blown transfer case??
2000 Dak 4x4. 4wd doesn't work, horrible grinding noise in 2wd, put in 4wd no noise but no 4wd. I can turn the front driveshaft freely by hand. Are both front and transfercase blown?? Help thx.
Old 12-23-2018, 09:33 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,189 Likes on 2,942 Posts
With the truck in 4x4, you can spin the front shaft by hand????? That just ain't a good sign......
Old 12-24-2018, 09:08 PM
00t444e's Avatar
00t444e
00t444e is offline
Have you ever checked or changed the fluid in the front differential or transfer case?
Old 12-24-2018, 09:17 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
Are the front wheels on the ground when you turn the front driveshaft in 2wd? If yes, the front diff is a goner.
If you can turn them it in 4wd with the wheels on the ground then both the t-case and diff have problems.
Quick Reply: Blown transfer case??
