rear traction ade
Old Feb 17, 2020 | 09:36 AM
wheily's Avatar
wheily
Default rear traction ade
does any one have a power trax locker # 92083822905 in there 8.25 axle ? if so how do you like it ? is it a good choice ..im just needing a little exstra traction when out on logging roads .. thanks for any info
Old Feb 17, 2020 | 10:43 AM
They are not inexpensive.... Detroit Tru-trac would be my pick, if money wasn't a problem. (they are almost 700 bucks, just for the locker....) If you wanna go less expensive, maybe a lunchbox locker?
Old Feb 17, 2020 | 05:03 PM
00t444e's Avatar
00t444e
I put a Spartan locker in the rear of my Dakota and it worked great.
Old Feb 17, 2020 | 10:34 PM
magnethead's Avatar
magnethead
I have a lockright in my 8.25 and it works like a dream. I'm sure my 408 swap will fix that, though.
Old Feb 18, 2020 | 12:13 AM
Vimes's Avatar
Vimes
Until you get something in, you can lightly apply the parking brake and get a poor man's posi out of an open differential. The idea is an open diff sends all power to the wheel with no traction. Putting the parking brake on to keep the no-traction wheel from spinning will put power to both wheels equally, and being easy on the throttle can get you unstuck. Obviously this is hard on the parking brake, and something you only want to do when stuck but not buried.
I've had good luck with Eaton limited slip units, don't know if they're offered for Dodge rears. Can't imagine they aren't though.
Old Feb 19, 2020 | 04:37 PM
wheily's Avatar
wheily
thanks for the info ..i have got new tires that made a huge diffrence.. the last time i went wheeling theres one hill with mud that is the slimy kind but not more than a few inches deep...it took 4high 3rd gear , tack was saying 4000 rpm and speedo said 45 and i could have walked faster than truck was acually moving lol
Old Feb 19, 2020 | 04:40 PM
wheily's Avatar
wheily
also power traxs makes one for front diff as well..cense there are no hubs to disingage front axles would it cause any steering isuesor would it not matter as long as trucks not in 4x4 mode
Old Feb 19, 2020 | 05:03 PM
00t444e's Avatar
00t444e
I have one in the front of my Jeep you don't notice it in 2wd since there is no torque going to the front axle, however I wouldn't recommend putting one in an IFS axle, too much stress on the CV joints.
