What year? What have you done to it lately? Any codes?
. 1998 5.2 4wd
over the past year fuel pump & pressure regulator, plugs wires cap fuel injectors map sensor tps Iac valve ecm crank sensor I’m sure there’s more I’m at a loss coil pick up coil
. 1998 5.2 4wd
So you just did the cap and rotor what about replacing the distributor the pick up coil could be going bad
It started this morning run and seemed like it’s starving for fuel, I’ve gas in throttle body still don’t start I’ve replaced everything runs for a short time and again acts as if it’s starving for fuel
So no idea as to the brand of fuel pump? It matters. As I like to say, you install an Airtex fuel pump when you want practice changing fuel pumps. I will only use OEM, Carter, Delphi or AC Delco fuel pumps. Your local parts store can likely loan you a fuel pressure tester.
