Tranny or TC ?
Old Sep 29, 2020 | 06:50 PM
Dakotaa1's Avatar
Dakotaa1
Default Tranny or TC ?
Hey everyone. I have a 99 Dakota and the guy before me said his buddy rebuilt the transfer case and then said that the transmission was hooped. I just started it up and tried moving it just to see what would happen and there is a grinding whirring noise coming from the transfer case. Not the transmission. And when I first put it into drive it moved forward an inch or two before the grinding whirring noise. Do you think that his buddy maybe screwed up on his "rebuild"? Or is it the tranny? Hope someone can help. Please.
Old Sep 29, 2020 | 07:22 PM
Moving to second gen Dakota section for ya.
Old Sep 29, 2020 | 07:25 PM
Dakotaa1's Avatar
Dakotaa1
Default Ooops
Thank you very much.
Old Sep 29, 2020 | 07:34 PM
What engine/trans/t-case??
Sounds travel REALLY well thru the driveline..... It may be the trans, it may be the t-case.... If you put the truck in park, does it stay put?
Old Sep 29, 2020 | 07:54 PM
Dakotaa1's Avatar
Dakotaa1
Default Re
Thanks for the reply. Yes, it stays put whilst in park. Also, I had a buddy put it into gear while I was under the truck, so I pin pointed the sound to the front part of the T C.
Last edited by Dakotaa1; Sep 29, 2020 at 07:55 PM. Reason: Typo. Damn spell check changer
Old Sep 29, 2020 | 08:03 PM
Dakotaa1's Avatar
Dakotaa1
It has a 5.2 318 and a 42re tranny. I am not sure of the tc
Old Sep 29, 2020 | 08:21 PM
Wonder if the tailshaft of the trans doesn't stick far enough into the t-case...
Why did he rebuild the t-case in the first place?
Old Sep 29, 2020 | 08:58 PM
Dakotaa1's Avatar
Dakotaa1
I believe that he rebuilt it because the truck wouldn't move.
Old Sep 29, 2020 | 09:25 PM
Guess it wasn't the transfer case then, was it?
Drop the trans pan, see what you find.
Old Sep 29, 2020 | 11:00 PM
magnethead's Avatar
magnethead
Wonder if the splines are stripped out on the transmission output/transfer input.
