CTM Replacement
I have a 2001 Dodge Dakota SLT, 2X4, Quad Cab. Since I'd gotten it used two years ago, I'd had issues with the internal locks, lighting, and windows not working correctly. I had finally gotten around to having it diagnosed only to find out that the interior utility wiring was left unplugged from the CTM. Now I know why: the power locks keep locking and unlocking of their own accord with the engine being on or off. This is obviously a security risk that I want fixed, but I don't want to unplug the thing again.
The mechanic said I need to find a replacement, which is apparently a nightmare since it's discontinued. So I went through ebay to find something and came up with a couple possibilities, but I have some questions about what I'm seeing.
The p/n I have is 56045452AK. The ones I've found matching this are between two and three hundred dollars. By comparison, I've found a couple with different alphnumerics that are way less expensive.
General question: how similar do the p/n s have to be for them to be interchangeable in this vehicle?
Specific question: Will the p/n 56045452AL work in lieu of the AK? If so, do I need to have it reprogrammed to make the locks, lights, and windows work correctly? (Please note: I do not plan on using a key fob).
The last two letters are just the revision number. The "AL" will be a later revision than the "AK".
There were also two different CTM's..... Highline, and base, so, I am think the numeric part of the part number NEEDS to match. Not sure about the revision...... It *shouldn't* be an issue....... but, I have been wrong before.
If you ever have the PCM replaced without updating the CTM though, you will be screwed.
On 01+, a CTM swap can be VIN flashed using the DRB - it will read the VIN stored in the PCM and copy that to the CTM. Likewise, in a PCM swap, you use the DRB to tell the PCM to copy the VIN from the CTM.
Well, if you change the CTM, don't flash it, then change the PCM (which WILL throw MIL for VIN mismatch), then neither module has the correct VIN and you can be S.O.L.
Technically yes, as the CTM is VIN matched, however it won't throw a MIL for VIN mismatch to my knowledge.
Sing Cab Base
Sing Cab Premium
Ext Cab Base
Ext Cab Premium
Quad Cab Base
Quad Cab Premium
Single and Ext I'm not sure the differences, if any.
Also, something just occurred to me, if I got the thing flashed, would that possibly fix the problem or is that out of the ball park?
Trending Topics
The trick is finding a dealership with an actual DRB3. Many have disposed of them in varying methods (I got mine from a retiring tech). I'm not sure if the WiiTech's DRB Emulator can do flashing or not; I would think so? It's a rather mundane task compared to some DRB functions.
And no, re-flashing your current one won't solve the electrical gremlins, methinks.
With that said, you can always keep the faulty one with correct VIN. If you ever need a PCM programmed, you can swap it in on a temporary basis.
On paper, should only be whatever a dealer's minimum charge is. either 1 or 1.5 hours. The actual task takes 5 minutes.
One clarification though: when you say S.O.L., what do you mean exactly? Materially speaking, what's the worst thing that would happen to the vehicle if the PCM goes bad with a CTM not programmed to the VIN?
Thanks for the help. I just got a the new CTM with the AL Suffix and I'm going to gauge the cost of reprogramming it.
I don't know exactly which mismatches throw errors. I'm not sure which one that the state inspection computers check against (Usually they scan the driver door, while the computer reads the VIN off the comms buss, and those should match) and what the procedure is when the door VIN doesn't match the digital VIN.
PCM
CTM
Cluster
Airbag Module
should all ideally always be VIN matched.
