01 Dodge Dakota 2.5 liter
Old May 17, 2021 | 06:56 PM
Benperkins 106's Avatar
Benperkins 106
Default 01 Dodge Dakota 2.5 liter
So I have a Dakota that the temp sensor I guess went out and I didn't realize it . Got hot bout half mile from the house and when got home engine light came on . The code at first was p0303 . Went ahead and replaced please gs wires cap and button,reset the codes but still had the misfire .started doing some research and said it could possibly be the injector . So I pulled the injectorsand just so happened that the number three injectors was an oddball of the 4 .so I'm thinking ,yes, gotta be it . I pull the plugs and make sure there clean and went bout 30 feet doen the road and light came on again . P0203 this time , which is injector circuit malfunction .. so o proceeded to unbolt the harness and tear into it . I found two wires that were no part of the injection system and fixed them ,reset the light again. .drove it down the road prolly 5 miles and the light came back on . P0303 and p0300. So I check the resistance on the coil and it is perfectly in spec but I noticed 3 hairline cracks .....so me being out of work for a month now and running tight on money got the tape out to keep it from grounding out if by chance it was and it's still misfiring .so I pull the number three plug and put it in the plug wire to. Check the spark and it has spark but it is yellowish orange and looks weak . So I'm a bit puzzled on one thing cause I just can't find the answer .. all the injectors have the same green w orange stripe power wire and they all come together and continues to the coil and it has the same color power wire . I check the voltage on all the injectors plugs and it is 6.8v and theplug to the coil reads 6.8v is this normal i. I checked it with the key on .PLEASE SOMEONE HELP !!!!!!
Old May 17, 2021 | 07:43 PM
Nope. Should be 12 volts (or, battery/system voltage) at injectors and coil.
Old May 17, 2021 | 11:54 PM
98DAKAZ's Avatar
98DAKAZ
Question
you sure your engine is the 2.5 as they only have one coil not individual coils per cylinder. Dodge was experimenting with that system but never actually implemented it just fazed out the 2.5.
coil for a 2.5 is $10
if you do have individual coils and a 2.5 you have a rare Dakota or some aftermarket setup. If it is aftermarket I strongly recommend removing it and putting it back to stock.
Old May 18, 2021 | 12:21 AM
Benperkins 106
Default Reply
It a 2.5 with single coil . . So when the voltage comes out in front the battery does it have to go through relays or drivers or anything before it gets to the connectors or does it get converted after it makes fire ..not sure if you followed the entire post or not .and I know I get confusing sometime and see apologize .I really appreciate the
Old May 18, 2021 | 12:27 AM
Benperkins 106
Default No
Spoiler
Old May 18, 2021 | 12:38 AM
Benperkins 106
That's the thing, I tested the coil and its ok n spec .1.2 ohmslow side and I think like 26000 secondary
Old May 19, 2021 | 08:20 AM
98DAKAZ's Avatar
98DAKAZ
check your engine grounds and be sure the dash is grounded properly the two bolts that hold the dash on each side may be loose.
just check all grounds
Old May 19, 2021 | 08:28 AM
98DAKAZ's Avatar
98DAKAZ
you have a 01 my Dakota is a 98 so it may be different for you.
engine ground #1
engine ground #2
The dash ground pic
Old May 19, 2021 | 09:00 AM
98DAKAZ's Avatar
98DAKAZ
Thumbs up
I installed an extra engine to cab ground the 2.5 has an aluminum intake manifold pic included
