Help! I lost reverse
Old Oct 19, 2022 | 01:10 PM
Truckgirl5150's Avatar
Truckgirl5150
Default Help! I lost reverse
I've lost reverse in my 2001 dogde Dakota, it's the 5.9 engine the code says it's a sensor but mechanics tell me I need a rebuilt transmission big difference in price. I came home from work and parked. The next morning it wouldn't go n reverse. It trys to go n reverse n 4 low. It goes forward no problem but I have parked it not to cause anymore damage. Someone told me to try trannymech. Is that a good solution? I had the tranny serviced about 2 years ago and I don't use the truck often due to gas prices so it still has low mileage.
Old Oct 19, 2022 | 01:26 PM
Drop the pan, and see what you find. Might be as simple as a band strut fell out.
Old Oct 19, 2022 | 06:36 PM
supadoom's Avatar
supadoom
What is the code? Might just be a solenoid or a band. If its either of those its replaceable with by just dropping the pan. Get a second opinion at a transmission shop as well. If a mechanic ever jumps straight to rebuild after reading a code they are just upselling.
Old Oct 21, 2022 | 11:34 AM
hidden1's Avatar
hidden1
When i lost mine it was the overdrive an that,common problem, spring busted but its easy to replace....
i couldnt go into 2nd 3rd an no reverse .I replaced solinoid an sensors while in there an adjusted bands
Wasn't extremely difficult Sensors are there an accessable. I put another overdrive in . .Pull the pan an see what you have,look at the sensor that set code an check that accumulator spring. This was mine- busted-
Wnich sensor code do you have?
Old Oct 22, 2022 | 07:58 PM
Truckgirl5150
Default Codes
codes are 1765, 0753, 1740
Old Oct 22, 2022 | 08:59 PM
supadoom's Avatar
supadoom
p1765 is a lost 12v reference to the TCM relay. Usually a broken wire/ground or damaged relay. With the age of the truck either are quite likely. p0753 is a shift solenoid electric failure. Possible from the same source as the first code. p1740 is an overdrive solenoid performance code. All of these are electrical codes. I would look for a broken ground or pinched harness to the transmission. I'd bet money you got an easy fix here.
Old Oct 23, 2022 | 03:59 AM
Truckgirl5150
Thank you so much! I am putting it on a lift this Friday, I'll report back!
Old Nov 11, 2022 | 05:18 AM
Truckgirl5150
This is in the bottom of the tranny pan, what is it?
Old Nov 11, 2022 | 05:22 AM
Truckgirl5150
Old Nov 11, 2022 | 07:24 AM
Part of the o/d clutch retainer.
Likely not why you lost reverse though.
