Slight advance at stop
Old Apr 28, 2023 | 10:07 PM
Failing sensor? Maybe a vacuum leak in the canister purge system? Glitch in the matrix? Unfortunately, there are too many things that *might* cause it. Narrowing it down might require doing some data logging.
Old Apr 28, 2023 | 10:15 PM
hidden1's Avatar
hidden1
Matrix? ill see if hoses are secure at canister an look for air leaks...
Old Apr 28, 2023 | 10:22 PM
Yeah, The Matrix. Keanu Reeves??
Old May 5, 2023 | 01:01 PM
hidden1's Avatar
hidden1
You were spot on as i suspected...tranny code 1767.i guess i need to check the sensor..what readings should i get at harness?
Old May 5, 2023 | 01:55 PM
Governor pressure sensor code, isn't it? If so, just change the sensor and solenoid, and call it a day. Get the Borg Warner Heavy duty set. They work great, and solve a bunch of problems.
Old May 5, 2023 | 06:08 PM
hidden1's Avatar
hidden1
I havent had time to really look at data but whats it saying on that code ..? reverse clutch solonoid or gov switch or what? On the service manual.. Im sure i can change it out but want to be acurate..an confirm voltage to it too​​​​​​​UPDATE..that service manual jumps from p1736 to 1775. ! .makes no sence unless its some generic code..
Old May 6, 2023 | 10:32 AM
A/T Transmission Relay Circuit Malfunction is what I find. There isn't a reverse clutch solenoid in the trans.....
Basically, PCM thinks the trans is losing power. Could be a bad fuse, bad relay, or a bad connection somewhere. (most likely down at the trans.) Of course, some of the descriptions say "Trans relay always on"..... which would imply that even with the engine off, the trans relay is still on. And it shouldn't be. That one is easy to test.
Old May 6, 2023 | 01:14 PM
hidden1's Avatar
hidden1
Yes I just got done cleaning the connector an switching over relays ..an checking the fuses ..gonna test drive it..
on that connector which pin is in an out to trans pcm
Old May 6, 2023 | 01:22 PM
Several of 'em..... I don't have the pinout handy, but, should be able to find it here.
Old May 8, 2023 | 11:48 PM
hidden1's Avatar
hidden1
Thanks !!! I have a 1995 to 01 mitchel w CDs an loved it all even that transmission version an wiring diagrams..heres a diagram. So far it hasn't returned since switching relays an cleaning an securing harness..I may test the connector if it comes bk.. ​​​​​​​
