Slight advance at stop
Old May 17, 2023 | 04:21 PM
  #21
hidden1's Avatar
hidden1
I stuch another assembly off the same type tranny which included the transducer an gov solonoid.
So far its ok...Ill soon see.
It oddly took 6 quarts to get it back to correct level[ NOT 4 as all parts stores say]
Is there a test i can try on the old gov solinoid ,including the transducer ? Just curious?
Old May 17, 2023 | 04:28 PM
  #22
Not testable as far as I know.... at least, not without some pretty specialized equipment....
Old May 18, 2023 | 01:45 AM
  #23
hidden1's Avatar
hidden1
I didnt think so..So far its not advancing at the light anymore an a quieter idle..But a bit sluggish as far as take offs... No codes..an it seems to shift as its supposed to 1st to second an on..
Its like a little less rpm to go as light turns green..
Any ideas?
Old May 18, 2023 | 09:39 AM
  #24
That's probably a programming issue..... Not sure what would solve that one... maybe the Sonnax zip kit? Sure cure?
Old May 18, 2023 | 02:30 PM
  #25
hidden1's Avatar
hidden1
I did find this at the bottom of the pan ..not sure if its part of that ring piece. Any idea?
Old May 18, 2023 | 03:36 PM
  #26
Yeah, looks like part of the O/D snap ring.... it's a small piece though.
Old May 26, 2023 | 04:47 PM
  #27
hidden1's Avatar
hidden1
That fixed it!
is there a chance a band adjustment would give it a lift as 1st an 2nd gear need it a bit?
Old May 26, 2023 | 04:59 PM
  #28
Sure couldn't hurt.
Old May 26, 2023 | 06:46 PM
  #29
hidden1's Avatar
hidden1
What do the adjusters on outside of tranny do that differ from the ones inside?
Id like to try it on the outside ones 1st since its easier an no dropping pan.?
Are they for 1st /2nd shift? Outter ones ?
Old May 26, 2023 | 08:08 PM
  #30
One is the reverse band. The other is manual first, I think. Don't recall which is which though.
