Engine swap need help
Old May 10, 2024 | 04:42 PM
  #31
Manwithadodge's Avatar
Manwithadodge
Change the overdrive housing over.
Alright will do
Old May 11, 2024 | 12:07 PM
  #32
Manwithadodge
Originally Posted by Manwithadodge
Alright will do
Ok would it be easier to install the transmission with it already connected to the motor?
Old May 11, 2024 | 09:45 PM
  #33
In a dakota? I think trying to stuff 'em both in together would be difficult, at best.....
Old May 11, 2024 | 10:29 PM
  #34
Manwithadodge
Yeah it was fun, everything went together smoothly, gonna work into the night to plug up all the wires, thank you all for your help I appreciate it
Old May 19, 2024 | 01:52 PM
  #35
Manwithadodge
Finally runs, and drives, total swap cost was under 100 dollars
Old May 20, 2024 | 07:43 AM
  #36
Dodgevity's Avatar
Dodgevity
So what caused it to lock up?
Old May 20, 2024 | 11:31 PM
  #37
Manwithadodge
The torque converter on the old transmission wasn't fully seated and smashed into the pump, so I just swapped out transmissions and converted the 4x4 transmission out of the parts ram I had to 2wd, only problem now is the exhaust won't bolt up because the transmission line needs to be bent up and off to the side somehow
Old May 21, 2024 | 08:42 AM
  #38
Dodgevity's Avatar
Dodgevity
Does it have enough length to bend it?
https://www.harborfreight.com/tubing...caApELEALw_wcB
Old May 22, 2024 | 03:36 PM
  #39
Manwithadodge
Yeah I think so, there the same ones as on the V6, just gotta pull them up over the starter
