Rough 1-2 shift 45rfe
Old May 27, 2025 | 11:15 PM
grant1153's Avatar
grant1153
After doing some research it sounds like there’s a high possibility that the o ring isn’t properly seated on the flat felt filter, I found this forum post of a near identical situation as mine including the codes
https://www.dodgetalk.com/threads/do...-codes.335529/
i also get a lot of bubbles on the dipstick i noticed, not necessarily a ‘foam’ but just bubbles, which leads me to believe there isn’t a great seal on the ring/filter and air is getting sucked in, gonna have to suck it all out and drop the pan, hopefully it’s that simple
Old May 28, 2025 | 09:14 AM
Let us know what ya find.
Old May 30, 2025 | 10:53 AM
grant1153's Avatar
grant1153
So the verdict is in…I pumped out all the juice and dropped the pan, while I did not look at the o ring before unbolting the filter, the instant I removed the bolt for the filter it fell straight out, which basically confirmed it wasn’t seated properly or seated well at all (considering when I removed the original filter I had to use all my body and both hands to pull the filter out with the o ring still attached) and the o ring came down with it, I pressed the o ring in on its own first like the service manual apparently states then slid the filter up afterwards bolted it all back together filled her up and she runs like a new truck now
Old May 30, 2025 | 11:10 AM
Awesome. Glad ya got it working.
