Dodge Dakota 3.9 v6 slt misfire help please!
Old May 13, 2025 | 10:12 PM
Rmcc2002's Avatar
Rmcc2002
Default Dodge Dakota 3.9 v6 slt misfire help please!
So when I first start it up in the morning all is fine, doesn’t misfire or anything, but let’s say I go to the store then come back and then like an hour later I need to go back out or even a couple mins, it’ll misfire really bad, I’ll hear some not so good sounds under the hood like clicking or popping and it’ll either A) stall or B) have a surge of power then drive fine! Any thoughts? I’m scratching my head trying to figure it out
Old May 14, 2025 | 09:34 AM
How old are your plugs/wires/cap/rotor?
Old May 14, 2025 | 10:11 AM
Rmcc2002's Avatar
Rmcc2002
plugs are about a little over a year old, wires same, cap im not too sure what you mean, and like brake rotors? They’re a year old and in good condition
Old May 14, 2025 | 10:32 AM
Distributor cap, and the rotor under it. Key pieces of your ignition system.
Old May 14, 2025 | 11:43 AM
Rmcc2002's Avatar
Rmcc2002
I will check that as soon as I get back, any other potential issues?
Old May 14, 2025 | 12:02 PM
Many. Start with the easy stuff.
Old Jun 15, 2025 | 12:40 AM
Rmcc2002's Avatar
Rmcc2002
Alright I did the easy stuff and it’s still doing it what would be the next step?
Old Jun 15, 2025 | 08:55 AM
Moparite's Avatar
Moparite
Crank sensor is a real good possibility. Any codes? What spark plugs are in it? May want to check resistance on the ignition coil, If it's out of spec it could be bad.
Old Jun 15, 2025 | 09:17 AM
Rmcc2002's Avatar
Rmcc2002
there’s no codes, the ignition coil is about 9 months old I replaced it with the waterpump and alternator haven’t replaced the crank sensor though
