Clutch Pedal Adjustment?HELP!
Old Apr 28, 2006 | 11:35 AM
caddman84's Avatar
caddman84
Default Clutch Pedal Adjustment?HELP!
I have a problem and its really annoying me. My clutch pedal doesn't engage until almost let all the way out, which leaves almost no room for gradually taking off or smooth shifting. I just bought the truck. If anyone can let me know if there is an adjustment or where I can find a how-to article to adjust this please let me know. Thanks alot.
Old Apr 28, 2006 | 05:48 PM
batman13's Avatar
batman13
Default RE: Clutch Pedal Adjustment?HELP!
i have the same problem
it's not adjustable, the clutch is getting old
my sister had the same thing in her el camino she had to get the clutch replaced
you're gonna have to do it too. eventually
i'm gonna need to do it in couple weeks
as for smooth shifting you could learn to shift without the pedal
saves the wear and tear
________
Novana Residence Condo
Old May 7, 2006 | 04:17 PM
demarco0129's Avatar
demarco0129
My clutch is the same way, and the dealership i bought it from said that the clutch was adjustable...they lied. It is really hard to shift smoothly but I just dont have the money right now to pay 800 bucks for a new clutch. As for shifting without the pedal...what does tha mean? I am pretty sure you need to have the clutch in when you shift gears....?
Old May 7, 2006 | 05:21 PM
marks99dak's Avatar
marks99dak
truckers shift without using the pedal all the time i use to do it also
Old May 7, 2006 | 10:39 PM
batman13's Avatar
batman13
all you gotta do is get the RPM's and speed right and you can change gears, because the gears line up right and slip together
________
RosseBlack cam
Old May 9, 2006 | 12:52 AM
BlackDak07's Avatar
BlackDak07
i put a new clutch in my truck about 10,000 miles ago and it was still engaging at the top...
Old May 9, 2006 | 01:05 AM
demarco0129
So does anyone have any idea of how to get it to engage lower/more smoothly? I was sort of banking on the idea that it would help when i got a new clutch this summer...
Old May 9, 2006 | 05:17 AM
RP Racing940's Avatar
RP Racing940
ORIGINAL: demarco0129As for shifting without the pedal...what does tha mean? I am pretty sure you need to have the clutch in when you shift gears....?
Its when you match engine speed with trans speed. All teh clutch does is disengage teh trans from teh engine so teh gears will mesh.
Done wrong, or done improperly over time, you WILL screw your tranny up.
Old May 9, 2006 | 05:51 PM
batman13's Avatar
batman13
ORIGINAL: BlackDak07
you should get it checked, It should solve itself with a new clutch, i just doublechecked and there still is no way to actually adjust the pedal
________
UrSatisfaction
