torque
Old Dec 18, 2006 | 08:28 PM
dodgedakota98luver's Avatar
dodgedakota98luver
Default torque
Ok i have a 5.2 Magnum and i'm wanting more low end torque out of the motor. It already has exhaust and intake and has been hypertech programmed. What is the way to get the most bang for the buck?
Old Dec 18, 2006 | 08:46 PM
Chris's Avatar
Chris
Default RE: torque
One idea would be to swap gearing in the back.
Old Dec 18, 2006 | 08:58 PM
dodgedakota98luver
Default RE: torque
i dont want to kill my fuel mileage though the truck is already torquey as hell but i just crave more lol what about rocker arms? anyone know anything about them and the ratios and all that good stuff?
Old Dec 18, 2006 | 09:22 PM
Chris's Avatar
Chris
Default RE: torque
You could do the 1.7 rockers, however, most people will experience gains in the higher rpm range than whatI imagine you are looking for.
Old Dec 18, 2006 | 11:03 PM
dodgedakota98luver
Default RE: torque
yeah i want torque in the lower RPM's but i dont want to sacrafice any horsepower i already have in the higher RPMs
Old Dec 19, 2006 | 12:46 AM
horatio102's Avatar
horatio102
Default RE: torque
Then what you need is more displacement, higher compression ratio, or forced induction. You can run a lumpier cam but that'll most likely move your power band up in the RPMs. If you went with a lower RPM range cam it'll hurt your upper end horsepower.
Old Dec 19, 2006 | 05:47 AM
wink2873's Avatar
wink2873
Default RE: torque
wrong. Harland Sharp 1.7 rocker arms and a 48mm F&B throttle body will show horsepower and torque gains throughout the whole RPM range. These 2 mods on a 3.9 have shown up to 30 horsepower and similar torque numbers. A 5.2 is the same motor as a 3.9 except bigger, so expect to see the same types of gains.
Old Dec 19, 2006 | 12:59 PM
Twiztid's Avatar
Twiztid
Default RE: torque
I would go 50mm TB for the V8
Old Dec 19, 2006 | 03:00 PM
horatio102's Avatar
horatio102
Default RE: torque
ORIGINAL: wink2873
Got any dyno graphs before/after to back that up? I don't doubt that both hp and torque are added, but logic says it would shift the numbers up in the RPMs.
Old Dec 19, 2006 | 03:03 PM
Chris's Avatar
Chris
Default RE: torque
ORIGINAL: horatio102
ORIGINAL: wink2873
My thoughts exactly Horatio. I am sure that both numbers are up, however you will be seeing gains in the higher RPM range. I would also like to see the dyno results.
