Door Sagging.
Old Jan 30, 2007 | 02:48 PM
TrucksCostTooMuch's Avatar
TrucksCostTooMuch
Default Door Sagging.
I recently purchased a 97 Dodge Dakota Sport with 123k on it.
The Drivers side door sags. Any ideas on what to do?
Please go easy on me, I am a newbie.
Thanks
Old Jan 30, 2007 | 03:04 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: Door Sagging.
welcome to the site.
looks like you need some new door hinges. its an easy job if theres atleast 2 people.
Old Jan 30, 2007 | 03:09 PM
TrucksCostTooMuch
Thanks for the fast reply.
Will I have problems aligning the doors when I am done?
Should I order the hinges online or go to a dealer?
Old Jan 30, 2007 | 03:18 PM
Erich_121's Avatar
Erich_121
you should be all set, you will need a door stand or a helper to do it
Old Jan 31, 2007 | 07:10 PM
Dick Manley's Avatar
Dick Manley
go to a bone yard not a stealership
Old Jan 31, 2007 | 07:18 PM
Chris's Avatar
Chris
Make sure that the current hinges aren't simply loose. If they are bent, you could simply bend them back to normal. Compare them to the passenger side. That would be the cheapest solution; free.
Old Jan 31, 2007 | 09:37 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i had almost the same problem with the drivers door on my 98 extended cab it was rubbing on the door latch when it closed, all i did was put an 1/8th of an inch shim under the bottom hinge which brought the door up so that it was no longer rubing on the latch when it was closed
Old Jun 6, 2012 | 06:10 PM
Nick8216's Avatar
Nick8216
When you say shim...do you mean a wood shim? Where did you place the shim? I swung my 2000 Dakota front door open very hard and now the door needs to be slightly lifted 1/8 in to set the lock.
Old Jun 7, 2012 | 10:45 AM
dodgeramguy85's Avatar
dodgeramguy85
No wood will rot in the matter of months and you will find yourself doing it again. You need to shim it with a piece of metal.
Old Jun 7, 2012 | 11:34 AM
FACEMAN's Avatar
FACEMAN
Don't overlook the bushings. It might need them. Or pins as well.
