remote starter not workin right
Old Feb 21, 2007 | 11:36 PM
rtkota5point9's Avatar
rtkota5point9
Default RE: remote starter not workin right
Alright well first off, you got ignition 2 and accessory mixed up. Also, your truck has a 3rd ignition wire you must power up for it to start. You'll need to use a relay to do this. And starter is Blue/Yellow. They switched this in 2000. It should go like this.
12V constant - Pink/Black
Starter - Blue/Yellow
Ignition - Dark Blue
Second Ignition - Black/Orange
Third Ignition - Green/Red
Accessory - Black/White
Flip those 2 wires around and power up that third ignition and fix the starter wire andyou should be all set.
Old Feb 21, 2007 | 11:46 PM
Rakaric's Avatar
Rakaric
lol i tried so many thigns tho...i see no blue/yellow wire. imnothot told me it's further down so I'm gonna check that out. I already messed around with teh green/red wire..so i'm so confused with all the info i've researched..
Old Feb 21, 2007 | 11:50 PM
rtkota5point9
Well you defiantly have those ignition and acc wires switched, and you NEED to power up that 3rd ignition for it to run, so you're gonna have to fix those somwhere. How large is the yellow wire you are hooked to? It should be the same size as the ignition and constant wires and such. It should be a large, lighter blue wire with a yellow stripe.
Old Feb 22, 2007 | 12:00 AM
rtkota5point9
Im not telling you there may not be a problem somwhere else, but trust me, you'll need to fix those problems in the ignition harness as well. You should definatly have a Blue/Yelow wire for start, unless your truck is a 2001 and not an 00.
Old Feb 22, 2007 | 12:05 AM
Rakaric's Avatar
Rakaric
well...there's a yellow wire that goes from the switch and down the steering column, and it stay yellow as far as i can reach under the dash. I know it was starter cuz i probed it.
Old Feb 22, 2007 | 12:22 AM
rtkota5point9
Well fix the other ones and see what happens.
Old Feb 22, 2007 | 12:30 AM
Rakaric's Avatar
Rakaric
still does the same thing.
Old Feb 22, 2007 | 12:43 AM
Rakaric's Avatar
Rakaric
k new info..apparently the hood pin was grounded during startup. so that fixes teh flashin light prob. Now...it's trying to start...but no crank. I hear teh relays switching in teh fuse box and teh module buzzes..so I'm assuming that blue/yellow wire is the prob...but i cant find it :\
Old Feb 22, 2007 | 12:46 AM
rtkota5point9
It's there somwhere, trust me It's a lighter blue than the ignition wire, almost a pastel blue, with a very thin yellow line.
Old Feb 22, 2007 | 12:55 AM
Rakaric's Avatar
Rakaric
well i took a pic...I see wires aaaaall the way back there..is it like that blue wire?
