Front Axel
Old Mar 11, 2007 | 03:44 PM
  #21
imnothot02's Avatar
imnothot02
Default RE: Front Axel
this is correct^^^ but i was still assuming that this is a weekend fix till Monday when he is taking it to the mechanic
Old Mar 11, 2007 | 09:30 PM
  #22
dodgedakota98luver's Avatar
dodgedakota98luver
no i'm not taking it to a mechanici'd rather do my own work the only reason i had it at a mechanic in the first place is because i dont have the equipment to do an allignment. i think i'll just replace the boot and grease everything then drive it till it finally snaps. then replace the entire shaft. i'm just not going to romp the **** out of it in the mud
Old Mar 11, 2007 | 11:16 PM
  #23
f0x672's Avatar
f0x672
thats the spirit!
Old Mar 12, 2007 | 12:58 AM
  #24
imnothot02's Avatar
imnothot02
how much slop is in the joint now, if any, replace if that flys apart ull be out way more than 100 bucks
Old Mar 12, 2007 | 01:41 AM
  #25
dodgedakota98luver
i'm going to clean the joint several times with diesel to make sure there is no grit in it before i grease it and put a new boot on. I havent been driving my truck at all since i got the news so its not like its getting worse day by day. Tomarrow i'm going to start cleaning it. I had to finish my rust removal project before i started on this cause i had some bare metal on my door and figured i better take care of that first. Rust is gone holes are filled and i have it painted. Just need to wet sand it now.
Old Mar 17, 2007 | 06:10 PM
  #26
dodgedakota98luver
well yall are going to have to forget the front axel replacement tutorial. My CV was completly shot so i just replaced the whole thing. I started snapping pictures but then I broke off a bolt. and i needed some tools that i didnt have so i had to go buy them and the camera was just getting in the way. The good news is my truck is back on the road with a brand new front end. whole job took 7 hours with the luck i had.
Old Mar 17, 2007 | 08:19 PM
  #27
imnothot02's Avatar
imnothot02
wow! thats a long time...but atleast you have the pride that you did it yourself, and that you spent 100 buc ks instead of 600...
next time it will take ya 2 hours or so i would venture to guess!
Old Mar 17, 2007 | 10:24 PM
  #28
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yea assuming luck was on his side and he didnt break any more bolts or anything like that
