CB?
Old 03-18-2007, 11:42 PM
batman13's Avatar
batman13
batman13 is offline
Default CB?
I'm thinking of puting a CB in my truck.
I was wondering If some of you guys could point me in the right direction
I don't need anything fancy, I want a smaller unit that won't take up much space as I need every square inch.
and I don't want it to look gaudy or bulky.
Any ideas?
Old 03-18-2007, 11:53 PM
imnothot02's Avatar
imnothot02
imnothot02 is offline
Default RE: CB?
first off how far do you want it to go, smaller units don't have nearly the range... any uniden or cobra is a very good choice they all go about 3-5 miles but some can receive from farther away this is also greatly decided by you antenna setup
Old 03-19-2007, 12:00 AM
batman13's Avatar
batman13
batman13 is offline
Default RE: CB?
i don't need to go very far, 3-5 miles would be in my range actually
Old 03-19-2007, 12:06 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
Default RE: CB?
i would give up on the CB and do like i did, myself and all of my friends went out and bought motorola 2 way radios with a 10 mile range on them and we just take them with us when we go out they work between the cars and then some they are amazing just make sure that you get the ones with rechargeable batteries or else you will be spending alot of money on AAA batteries
Old 03-19-2007, 12:10 AM
jonnymagnum's Avatar
jonnymagnum
jonnymagnum is offline
Default RE: CB?
I have a uniden CB in the 88 and I have two 4' whips. I get pretty good reception. I dont really use mine alot, but it's came in handy acouple times. I really just only like the look of the whips
Old 03-19-2007, 12:12 AM
batman13's Avatar
batman13
batman13 is offline
Default RE: CB?
I won't use it daily for sure but it would come in handy plenty of times.
I have a handheld but I don't want another piece of crap floating around in the truck that i won't use 'cause i can't find it.
Old 03-19-2007, 12:16 AM
imnothot02's Avatar
imnothot02
Default RE: CB?
when we were kids we used to play a tracking game with cb's somthing liek this is what i had http://cgi.ebay.com/COBRA-25-NW-CB-R...QQcmdZViewItem
but that isnt realy a stock cb...
here is what i recommend for a antenna
http://cgi.ebay.com/K40-49-Trucker-C...ayphotohosting
dont get a window mount antenna or dual whips behind the cab, this is not a good way to use any radio being that the cab blocks your signal...
Old 03-19-2007, 01:06 AM
f0x672's Avatar
f0x672
f0x672 is offline
Default RE: CB?
i have a cobra 27, its about $130..good radio, has weather stations and the SWR calabration dial so you dont need to buy the unit by itself as well, and the Lil Wil Wilson Magnet Mount cb antenna is perfect, hold on to about 105 mph
Old 03-19-2007, 01:11 AM
imnothot02's Avatar
imnothot02
Default RE: CB?
+1 on the SWR cal
Old 03-19-2007, 02:24 AM
01dakota's Avatar
01dakota
01dakota is offline
Default RE: CB?
I have a Uniden PC68XL. It works great. I also have a 2 ft fiberglass antenna that I mounted right behind the cab that has a wire for the ground. I ran it down behind the cab and bolted it to the frame. The setup works great and I have no problem talking or recieving for 6 miles. I drive highway everyday and the truckers can be a greatbeardetector. I also have the same setup in my truck at work except I have a 4 ft fiberglass antenna mounted to the mirror. I personally think the 2 ft works better because of the ground wire. I get less static with that one.
