Engine swap ideas
Old 07-31-2017, 09:54 PM
Alan26's Avatar
Alan26
Alan26 is offline
Default Engine swap ideas
wondering what engines that could be swapped into my 4.7L magnum 2002 dodge dakota sport 4x4. Also want to know what I'd have to do extra like trans, axles, frame reinforcement, etc for the engine being swapped in.
Old 08-01-2017, 08:23 AM
jkeaton is online now
Dodge Forum Administrator
With enough money, time and tools, anything can be swapped in. What are your plans? Mudding? Drag racing? Pulling? Daily driver? Help us help you by narrowing it down and providing some details.
Old 08-02-2017, 10:06 AM
Alan26's Avatar
Alan26
Alan26 is offline
i was thinking of making it into a truck that I'd drive daily but be able to race people. My dream was to put a 408 stroker into the truck but I'd also like to know what else i can swap into it.
Old 08-02-2017, 10:21 AM
Race, as in a drag strip? Circle track? Mug bogging?
Old 08-03-2017, 05:04 PM
Alan26's Avatar
Alan26
Alan26 is offline
drag race pretty much, but also daily driver. Maybe in the future turn into a pulling truck.
Old 08-05-2017, 10:45 AM
HeyYou is offline
Received 3,208 Likes on 2,959 Posts
How much are you willing to spend?
Old 08-06-2017, 01:02 AM
44dakota's Avatar
44dakota
44dakota is offline
id put a 4bt cummins in it, you can compound the the turbos for more umphh!! if you need more..
Old 09-17-2017, 08:08 PM
Alan26's Avatar
Alan26
Alan26 is offline
Not really worried about the cost. I was thinking of putting dana 60 axles in the front and rear of the truck. Just wondering what engine and trans would be a good goal to work towards. For example a mopar 408 stroker with a 727 trans or a 383 stroker with a 700r4 trans. I also like the cummins idea.
Old 09-17-2017, 08:54 PM
magnethead's Avatar
magnethead
magnethead is offline
Being a 4.7, you are starting behind the 8 ball. You can's swap in a pushrod magnum without gutting the engine bay and starting from scratch with a pushrod magnum wiring harness.
To swap in a pushrod magnum (stock everything) is close to $6,000
To swap in a Hemi (stock everything), you're looking close to $10,000.
To swap in a pushrod magnum stroker/all-out motor, around $12,000
To swap in a Hemi all-out motor, around $16,000
To swap in a 4BT, probably $8,000 to $12,000
To swap in a 6BT, it's practically impossible. The frame is too weak in the front. By the time you reinforced everything, you'd be close to $15,000
I've worked & billed on $50,000+ custom builds at a shop I was the GM of. I know what (stuff) costs when you start tacking labor hours and fabrication materials on.
Old 09-20-2017, 09:14 PM
Alan26's Avatar
Alan26
Alan26 is offline
Any work on the truck will most likely be done by me and my teacher at my Votech school. Would I need a different transmission and/or transfer case? Also is there any other engine swap option? A gas motor would be great but I'd also like the 4bt idea and like to know some more about what I'd need for it.
