2nd Gen Durango 2004 - 2009
Interior lights won't turn off!
Old Jan 22, 2008 | 06:29 PM
jd176's Avatar
jd176
Default Interior lights won't turn off!
Like the title says, they won't shut off. Sometimes it's all of them, sometimes it's just the rear hatch light. Getting tired of jumping the wife's car so I took the light out of the rear hatch, hopefully that stops the battery drain. Anybody have any ideas on where to trouble shoot this? It seems to have a problem with the headlights too, turning on when the switch hasn't been touched.
Old Mar 11, 2008 | 04:03 AM
richie187's Avatar
richie187
Default RE: Interior lights won't turn off!
I have the same problem on my 04 durango. all the interior lights come on when i start the car and wont go off for 15 to 20 minutes. i heard it was something with the gauge cluster. but i wanted to see if anybody knows how to fix.
Old Mar 13, 2008 | 10:01 AM
master tech's Avatar
master tech
Site Moderator & Tech
If you are still under warranty, you may want to go to the dealer. Sounds like the cluster has a problem. By any chance did you have the recall done?
Old Mar 14, 2008 | 11:33 PM
richie187's Avatar
richie187
i didnt have the recall done, i was wondering if that couldcause it or if its something else not related to the recall.
Old Mar 20, 2008 | 04:14 PM
Jim H's Avatar
Jim H
I have started having some of the same problems. Recently I had to replace the battery after 3 years on my 05 Durango. As soon as we got the new battery in I started having problems. It's a Sears Diehard, which I've had before in other cars with no problems what so ever. The first problem was with the Low Inflation Indicator Light. It hadn't gone off in the 3 years that I owned the vehicle. Not it just stays on all the timeand I've had the tire company that I purchased the vehicle from recheck the pressure. The second problem I've had is the rear cargo lamp light comes on anytime I open the rear hatch. Now, I have toslam the rear hatch super hard for this light not to come on or stay off. I have never had to do this before. I didn't have the recall done but I'm considering it now. Any other suggestions on what I can check myself ?
Old Mar 25, 2008 | 09:31 PM
damram1980's Avatar
damram1980
all u need to know, http://www.lemonauto.com/complaints/default.htm
there was 1 or 2 on my wifes durango but the dealer fixed it for free,obviosly, its there prob, lol but other than that no probs.
just wondering what kinda mi. u guys got? 74,000 on the durango, and 43,000 on the ram
Old Apr 8, 2008 | 12:35 PM
n8ech's Avatar
n8ech
LD:
If you continue to see wierd things happening like your D is possessed, could be your CTM. I have an 01 D, and my weirdness started with the door interior lights coming on by themselves as you ride down the road. Next was the door locks unlocking themselves. This was followed by repeated soundiing of the warning chime that tells you to check the gauges, but they all appear fine. Final straw is the rear wiper coming on by itself randomly.
I have an appt. with my dealer next Monday. I will let you know how things turn out. Info I have is that a dealer installed CTM is $300-400.00
Don
Old Apr 18, 2008 | 11:15 AM
n8ech's Avatar
n8ech
JD:
In my case, the CTM diagnosis was correct. $485 later and all is back to normal. If you continue to have things come on by themselves, I would look into this possibility.
Good Luck Don
