2nd Gen Durango 2004 - 2009
Fill plug on rear diff
Old Mar 15, 2010 | 11:30 AM
01ssreda4's Avatar
01ssreda4
Default Fill plug on rear diff
Paperwork says the truck has the 9.25 rear end. I was gonna do a rear fluid swap, and I cant find the fill plug. Its the rear that has the bar (cant think of the name of it) bolted into the rear diff cover. Any help??
Old Mar 15, 2010 | 01:18 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Mine does not have a fill plug either as you will need to unbolt the assembly,
FF
Old Mar 17, 2010 | 08:42 PM
01ssreda4's Avatar
01ssreda4
Do you use the hole in the rear cover as the fill plug? Does the hole even go all the way through? Forgot to mention its an 06 Durango.
Old Mar 18, 2010 | 07:58 AM
1969CoronetR/T
vaffanculo
The differentials do not have plugs,
FF
Old Mar 18, 2010 | 04:58 PM
01ssreda4's Avatar
01ssreda4
I see that, how do you fill them then??
Old Mar 18, 2010 | 07:44 PM
1969CoronetR/T
vaffanculo
You have to unbolt the assembly,
FF
Old Mar 19, 2010 | 01:27 PM
01ssreda4's Avatar
01ssreda4
forgive me for not understanding. I was under the impression all rear diffs had fill plugs. What assembly are you referring to? Does anyone know off hand the amount of fluid the 9.25 rear end holds and what the cover is made of? I may weld a drain and/or fill plug in it when I remove it.
Old Mar 19, 2010 | 02:55 PM
1969CoronetR/T
vaffanculo
https://dodgeforum.com/forum/2nd-gen...-question.html
You would need to unbolt the the covers and clean out the gears and then fill. My mechanic claims there are no fill plugs, but I have read contrary to this and there are fill ports on both axles. You should unbolt the cover to clean if this is the first change,
FF
FF
Old Jun 28, 2010 | 01:03 PM
01ssreda4's Avatar
01ssreda4
So, use the axle fill tubes after i pull the cover and replace it?
Old Jun 28, 2010 | 06:27 PM
Big_Wheel's Avatar
Big_Wheel
there is a fill plug---NOT A DRAIN PLUG.... to drain it you much unblot the cover-starting from the bottem and then work your way around either side.
If there was no Fill plug--- you wouldnt be able to fill it unless the whole diff was out on the ground blocked up with the cover facing upwards.
