2nd Gen Durango 2004 - 2009
2006 Durango 5.7L Code P0406 Error help
Old Aug 30, 2010 | 09:29 PM
Cainlord's Avatar
Cainlord
Default 2006 Durango 5.7L Code P0406 Error help
my wife just got this code on her 06 Durango limited, I looked online and found this:
https://dodgeforum.com/forum/3rd-gen...rk-w-pics.html
is the fix basically the same for the Durango? I reset her check engine light, will see if it comes on again. but need advice on how involved is the fix, and how much is a common fee from a mechanic as far as repair cost, and estimate time it takes for them to do it.
I am figuring out here its about $70hr, if the part is about $40 from what I saw online, can i expect a a bill of about 1 - 2 hrs labor + the part?
also found this:
http://dodgeram.info/tsb/2007/18-027-07.htm
sounds like it is related to what I am experiencing?
thanks for any advise.
Old Aug 31, 2010 | 12:41 AM
PokerMunkee's Avatar
PokerMunkee
EGR valve, common issue. Buy it for $40 at your local auto parts store and replace it yourself.
Check this out:
http://tinyurl.com/23rcfut
Old Aug 31, 2010 | 09:38 AM
Cainlord's Avatar
Cainlord
thanks for the link. so then the issue in the TSB doesn't clear up the issue you still need to replace the part?
Old Aug 31, 2010 | 01:21 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Here is another link for the trouble code:
http://www.bba-reman.com/content.asp...NEXT_DTC_P0406
FF
Old Sep 9, 2010 | 12:12 PM
Cainlord's Avatar
Cainlord
looks like its a replace issue here as the light is back on. so will report back what I find.
Dealership is wanting like $100+ for the part, and also said I need some gasket that is like $11? anyone know what that gasket is?
So in short, about $180 for parts and labor. may just give this a try then as I have coworker whose into cars heavy, and her husband is willing to help me switch it out.
Would be my first real car work!
