2nd Gen Durango 2004 - 2009
2006 dodge durango sways bad when towing
Old Jan 30, 2011 | 10:13 AM
sbtadt's Avatar
sbtadt
Default 2006 dodge durango sways bad when towing
Hello what can i do to my durango. When i tow my 26ft camper the truck sways so bad iam worried i will lose it one day with me and the family in it.. I have weight dist. Hitch with to anti sway arms still not good enough any ideas please
Old Jan 30, 2011 | 10:17 AM
sbtadt's Avatar
sbtadt
Default 2006 durango front end clunks
Hello
Old Jan 30, 2011 | 02:19 PM
IndyDurango's Avatar
IndyDurango
What? No one replied to your original message inside of 4 minutes so there was the need for an additional "hello." Oh my... let me help.
Hello.
Old Jan 31, 2011 | 05:11 PM
TJDurango2006's Avatar
TJDurango2006
I think that second "hello" was a boo-boo.
Check the alignment of the wheels on the trailer. Check all tires (Durango AND trailer) and make sure they are at the recommended pressures. Also, if your anti-sway bar has something to increase/decrease the tension, you may want to increase it to get rid of the trailer sway.
How are you loading your trailer? Do you put everything towards the front?
I tow a 26ft travel trailer, as well, and do not experience trailer sway unless it is really windy.
Old Jan 31, 2011 | 07:30 PM
NoFearEyes's Avatar
NoFearEyes
I just towed my boat for the first time behind my 2005 Durango (5.7 w AWD).
The boat is a 26' center console with twin 200/s and hard t-top. Boat and trailer weigh about 8500#.
The tow was great--as good or better than my 2002 RAM 1500 quad cab. The Durango mileage with the 5.7 was around 12 per the trip computer. My RAM was being nice to me if I got 7-8 mpg towing same boat.
There was no sway and I dont have the load levelr torsion bars--just the factory hitch and heavy duty draw bar.
My concern was stopping. The Durango brakes don't do as well as the RAM did or the Ford F150 I had before that. I'm going to upgrade the trailer brakes and that will solve that problems.
I feel like the Durango is goin g to be a great vehicle---I'm really pleased with the choice.
Old Jan 31, 2011 | 07:36 PM
sbtadt's Avatar
sbtadt
when i load the tralier i put all the really heavy stuff over the axles like ur supposed to and i give the trailer a little weight up front. when i had a chevy tahoe i never had this problem so i just thought that it had to be the truck.
Old Jan 31, 2011 | 10:13 PM
MIKEon22s's Avatar
MIKEon22s
Default Swaying
The factory shocks are designed for a plush/comfy ride. Also they wear out very fast. Bilstien shocks make all the differnce. Also 10% of trailer weight should be on the ball. The trailer should be level or slightly angled down to the ball.
Old Feb 1, 2011 | 12:32 AM
TJDurango2006
sbtadt: You are not putting enough weight on the tongue, and is leading to your trailer sway. Read this article, and note the section marked "Trailer Loading".
http://www.etrailer.com/faq-trailertowtips.aspx
I'm not sure who told you put the heaviest stuff over the axle, but that was bad advice. When I bought our TT, we were told (and I had also read it somewhere, as well) to load to the front of the TT.
Here's another article about proper loading, and how to get the tongue weight (to avoid overloading the tongue).
http://www.hitchingup.com/tongue-weight.htm
