more horsepower
Old Jul 9, 2007 | 08:04 PM
kiel420's Avatar
kiel420
Default more horsepower
i have an 03 neon r/t and i want to start adding some mods. ive never had a car worth upgrading so im not to sure where to start. any comments?
Old Jul 9, 2007 | 08:44 PM
GrApHite03's Avatar
GrApHite03
Default RE: more horsepower
less money on weed = more money on mods
take your addictions one at a time. lol
Old Jul 9, 2007 | 09:07 PM
03neonRT's Avatar
03neonRT
ORIGINAL: GrApHite03
Lol!
But on a serious note...you can start with: cold air intake, longtube header, Comp 400 Camshaft, Unorthodox Underdrive Pulley, DOHC pistons, full catback exhaust, 60mm TB, P&P Cylinder head/Intake manifold and port match. Those are for starters...
Old Jul 9, 2007 | 09:36 PM
yellowO3r/t's Avatar
yellowO3r/t
ORIGINAL: 03neonRT
Lol!
03neonrt: taken if someone added those suggested mods, what number range do you think that would make.
Old Jul 9, 2007 | 09:57 PM
03neonRT's Avatar
03neonRT
ORIGINAL: yellowO3r/t
ORIGINAL: 03neonRT
Lol!
If you added ALL of those mods (and all the P&P work was agressive and well done) then you would probably be in the 150-160 range...which is about the max your going to see on the 2.0 without going to a much larger cam (#005) and something like MS'n'S, among other things.
Old Jul 9, 2007 | 11:33 PM
kevo1123's Avatar
kevo1123
would the longtube header be compatible with all 2gens without cutomizing the exhaust?
Old Jul 9, 2007 | 11:37 PM
03neonRT's Avatar
03neonRT
ORIGINAL: kevo1123
Well, anyone with a Magnum head would need to buy a LTH with Magnum ports. However, in any case you would need to remove the catalyctic converter for the LTH to fit, and then either keep it removed or have it welded back in after the header on the midpipe.
Old Jul 9, 2007 | 11:40 PM
kevo1123's Avatar
kevo1123
and theLTH would bolt up to the rest of the exhaust or would a flex pipe or something be needed?
thanks
Old Jul 9, 2007 | 11:48 PM
03neonRT's Avatar
03neonRT
The long tube header will bolt up to the rest of the exhaust system. A flex pipe may be needed...but I'm not 100% positive either way.
Old Jul 9, 2007 | 11:50 PM
kevo1123's Avatar
kevo1123
cool, thanks for that.
