ok the thing will not rub your tire as long as you have the splash guard there.
on quality, you are buying a tube. nothing more nothing less. it goes to the same place. the only difference is if you get a bracket to hold up your throttle body, which you will need and if there is something to replace the accordian thingy which is not necessary, but nice. you might get 1/2 more hp with a k&n which means nothing. it is however important to get a k&n filter to go on the end of it
its easy to install, theres a howto in the sticky i think. get the replacement filter for a dodge neon so if you ever decide to get rid og the cai you can still use it
